my top wont go up!
Old Nov 20, 2005 | 08:44 AM
Nhan's Avatar
Default my top wont go up!
seems like there's no electric current after hitting the top up/down button......
the top is currently down at the moment, but the switch isnt making it go up. my battery recently died, i just jump started it, but my top won't go up..could there be other reasons? fuse/messed up wire?
Old Nov 20, 2005 | 09:15 AM
xviper's Avatar
Is your ebrake pulled?
Old Nov 20, 2005 | 09:32 AM
Nhan's Avatar
yeah it is...
i've been removing panels and stuff, idk if i messed up any electrical wire?
Old Nov 20, 2005 | 10:06 AM
xviper's Avatar
What panels? What have you been doing?
I would suggest going back behind or under those panels and double checking to make sure no wiring harnesses or switches have been disconnected or shifted.
When you pull the ebrake up, does the dash light come on? If it doesn't, that might be something to look at.
Old Nov 20, 2005 | 10:18 AM
Nhan's Avatar
yeah i noticed that the "BRAKE" isnt on in the dash..xviper, what should i be looking for under the center console?? the harness is connected to the top switch..
Old Nov 20, 2005 | 10:25 AM
Silver9k's Avatar
just pull the center console up...its really easy, make sure both of the harnesses are conected...there are only two harnesses under there, one for the brake lights/hazards, and one for the top up/down switch.
they can only fit into their respective matching harness so you really cant mess that up
Old Nov 20, 2005 | 10:41 AM
xviper's Avatar
At the base of the ebrake handle, you should see a switch with wires coming out of it. Make sure the switch is being pushed when you pull on the ebrake. Do it with your finger if you must just to confirm the dash light. Then follow the wires as far as you can see to make sure the next harness is OK.
Old Nov 20, 2005 | 01:42 PM
gyrofx's Avatar
or just do the no e-brake top down mod...then you'll have nothing to worry about...just don't try to drop your top with the clamps in....
Old Nov 20, 2005 | 02:25 PM
Brian@Partshelper.com's Avatar
perfect time to buy a hardtop!
Old Nov 20, 2005 | 06:29 PM
XclusiveAutosports's Avatar
By any chance did you have the center console pulled out recently? Maybe you forgot to reconnect the two wire harnesses under there for the top up/down switch and the hazards. Just an idea
SSM-9Krev
Dec 24, 2015 03:46 PM
StormTroopinAP2
Jan 28, 2011 11:53 AM
TrackStar
Jun 16, 2010 12:36 PM
thefishstick
May 2, 2010 02:45 PM
145
Jul 17, 2002 05:20 PM
