oem silverstone touchup paint sucks
Old Apr 10, 2006 | 06:43 PM
nrgizeman's Avatar
Default oem silverstone touchup paint sucks
i read that silverstone is hard to match and perfect matching touchup paint is hard to find. well i bought one from the dealer and the color is way off!!! i double checked the paint code and its correct however shade is way too dark. instead of oem, what can i use for touchup. in advance... thanks a bunch!
Old Apr 10, 2006 | 07:39 PM
gomarlins3's Avatar
Same thing happened to me on the Insight. Paint code matches, but the color sure doesn't.
Old Apr 10, 2006 | 08:08 PM
sunnyyan's Avatar
same thing here, I touched up my silverstone with OEM touch up paint, even though I was very careful by applying very thin layers, but still turned out disappointing.
Old Apr 10, 2006 | 08:11 PM
SIIK2NR's Avatar
Try taking a portion of your OEM paint and add a drop of sebring silver and you will get the correct tint..
Old Apr 10, 2006 | 09:19 PM
DrDre1443's Avatar
Mine looked real dark too. I shaked it for a good 5 minutes, swirled the brush inside to make sure it was completely mixed well, and applied a tad to my hood. It was perfect.
Old Apr 11, 2006 | 02:10 AM
RM 4 2's Avatar
I found that apply it in direct sunlight turns out better than do it in the shade, I shake it more than 10 min., though.
Old Apr 11, 2006 | 05:59 AM
Kenny_Stang's Avatar
I had the opposite happen to me mine was lighter, looked more like Sebring Silver than Silverstone.
Old Apr 11, 2006 | 06:38 AM
hkspwrsche's Avatar
Good advice on here so far.
Even if you were spraying the exact color out of a spray gun you could adjust the color by adjusting the air pressure!
A more wet spray will bury the metallic and a dry spray will make metallic lighter. This metallic distribution applies to brushing also.
Mixing it thouroughly is very important. Following that if it is mixed thouroughly then you may need to apply enough coats if it is not dark enough or is to light. If the primer or steel is showing thorugh and is darker/lighter more/less coats may be needed.
Apex1.0
Oct 19, 2017 10:51 AM
RonnieG
May 18, 2013 10:07 AM
Morrisbaddass
Aug 25, 2010 06:26 PM
shiesty
Dec 5, 2005 09:20 PM
Cape Cod
Aug 16, 2002 06:42 AM
