Oil filters for the S2000
you can try what I try, go to a honda dealer and tell them you work for an acura dealer and he should give you a discount, no question.
I my friend tried that and he allegedly work at a acura across the street and got me the oild filters for 4 bucks each
Originally Posted by patinum,Sep 18 2009, 12:02 PM
I bought a 6 pack of filters and washers from http://www.handa-accessories.com/s2000-04maint.html
Tip- when you get the filters and washers - tape the washers to the top of the filters. That way, 2 years from now when you're on your 6th filter, you'll still have that washer around.
There are slightly cheaper prices on some of the other Honda parts sites (a few cents here, a buck there), but handa-accessories has BY FAR the easiest website to navigate and understand if all you want is maintenance items. I like that they make it easy to identify fill/drain washers for common uses. On other sites you have to pick apart complex diagrams just to figure out which washer you need. They pack stuff well and the big zip-lock bags they put liquids in are great for other uses because they are so big and tough.
Originally Posted by PanteraKitty,Sep 18 2009, 11:00 PM
Here is the current link to the Oil Filter Study.
http://minimopar.knizefamily.net/oilfilters/index.html
I use the Motorcraft/Purolator filters.
Originally Posted by macr88,Sep 18 2009, 10:49 PM
I took an Amsoil filter appart for the S2000 and did not like the fact that the bypass spring was extremely weak compared to the OEM filter (both OEM versions). The filter media seemed to be of good quality but what use is that if it's always bypassing.
Once I run out of filters I'm going to use CM filters along with Amsoil oil.
I use fram ph3593 (filter) and Casterol oil,
a usual oil it has worked well so far...
flame suit on, I know many will
my use of the fram filter
Im kind of weird though because I do my cheap oil changes but I never put anytthing but Chevron supreme in the gas tank
a usual oil it has worked well so far...flame suit on, I know many will
