Ok, So how do you get the Air out?
Old Mar 15, 2001 | 05:12 PM
krazik's Avatar
Administrator
After reading the Nitrogen thread, I got to thinkin'
Lets say someone actually wanted to put nitrogen in their tires, how exactly do you get *all* or near-all the air and problematic water vapor out?
Old Mar 15, 2001 | 05:25 PM
Utah S2K's Avatar
Remove the Schrader Valve completely. Replace valve and put the good stuff back in. Oh...the Schrader is the little one way dohickey that keeps the air in the tire.
Old Mar 15, 2001 | 05:29 PM
krazik's Avatar
Administrator
that isn't going to remove all the air... that will just equalize the pressure w/ the ouside.
Old Mar 15, 2001 | 05:39 PM
cdelena's Avatar
There are machines (http://www.nitronics.com/tirelast.htm) that purge and refill the tires.. I don't how you manage it if you just have a tank.
Old Mar 15, 2001 | 05:45 PM
josh3io's Avatar
you have to have a special valve "thingy" that allows you to attach a vacuum pump and a fill tank, without air from the tank going to the vacuum side.
Old Mar 15, 2001 | 05:49 PM
laster's Avatar
IF you're not a complete fanatic you could pressurize and bleed a couple of times. That would leave a very low percentage of anything but nitrogen. Nitrogen is not expensive once you own the tank.
Old Mar 15, 2001 | 06:41 PM
Mindcore's Avatar
And I was just gonna say SUCK!
AS for the real answer, I just dont know
Old Mar 15, 2001 | 07:19 PM
dwb1's Avatar
remove schrader valve , hook up refrigeration manifold , hook up vacuum pump to one port and nitrogen to another . run vacuum pump to remove air . break vacuum with 15 lbs of nitrogen . remove hose from tire quickly install schrader before all nitrogen pressure is out of tire . purge nitrogen hose ( attach hose to tire while letting nitrogen run at low pressure through hose ) fill tire to pressure you want.
this is how you fill air conditioner .
brad
6410
camuman
Dec 4, 2008 10:12 AM
Purple Haze
Nov 4, 2006 09:31 PM
WalkingDrunken
Apr 16, 2006 07:51 AM
WalkingDrunken
Feb 23, 2006 04:20 PM
Tanqueray
Nov 15, 2001 02:40 PM
