OPTIONS FOR FUEL&TIMING; TURBO KITS
Old Dec 3, 2004 | 08:06 PM
sportridermike's Avatar
Default OPTIONS FOR FUEL&TIMING; TURBO KITS
I'm researching doing a turbo kit for my car, and have a few questions...
To those that have turbo S2Ks... How does your turbo kit deal with engine management?
The low-tech approach appears to be an upgraded fuel pump & fuel pressure riser, with stock injectors, and no timing adjustment.
The higher-tech methods tend to use upgraded fuel pump, injectors & AEM or E-manage to adjust timing.
What are some other approaches taken?.. from low to high-tech & in between.
Other than AEM or Greddy, how else could you adjust timing (lower-tech method)?
Thanks, Mike
Old Dec 4, 2004 | 03:56 AM
fperra's Avatar
To my knowledge, there are no other methods to adjust timing. If you are not going to run more than 7 psi, you don't need to worry about adjusting the timing. The stock ecu will take care of it. If you are going much above 7 psi, get an AEM ECU.
Old Dec 4, 2004 | 08:47 AM
buzilanga's Avatar
Why wont anyone think of using a Microtek computer?
Old Dec 6, 2004 | 06:17 PM
timg's Avatar
A-spec did!
Tim
Old Dec 6, 2004 | 06:19 PM
timg's Avatar
I'm running an AEM ECU for fuel and timing on mine.
Doesn't Split Sec also offer something to control timing?
Tim
Coronangel
Jan 13, 2019 11:50 PM
Dize
Jan 19, 2014 11:16 AM
brendanj85
Nov 1, 2011 10:17 AM
Diddy
Aug 26, 2003 11:20 PM
Reignman
Jul 15, 2003 09:11 AM
