Over-Rev vs. Rev Limiter
Old Oct 11, 2004 | 06:38 AM
freq's Avatar
Default Over-Rev vs. Rev Limiter
So let's say while going for a pass you have brain fade for a second and bounce off the Rev-Limiter for a second while going from 2nd gear to 3rd. Is this considered an Over-Rev, if not, what exactly is an Over-Rev?
Coming from a motorcycle background hitting the rev-limiter on a bike on occasion is no big deal but have never really heard about over-revs until now.
Enlighten me please.
Old Oct 11, 2004 | 06:43 AM
thatguyjosh's Avatar
The rev-limiter cuts the fuel off to the engine when you go past redline. Like when you are in a gear, after 3 blinks the rev-limiter will cut fuel off so you don't damage the engine. Over-rev usually occurs when you shift into the wrong gear. Like you're in 3rd and you try to shift into 4th but you accidentally put it in to 2nd. That nasty whining sound you hear from underneath the hood, that is over-revving.
Correct me if I'm wrong..
Old Oct 11, 2004 | 07:30 AM
freq's Avatar
If you are going through the gears, upshifting like normal, and you take it past 9,000 rpm's then yes the rev limiter will kick in cutting the fuel and preventing you from OVERREVING. However, if you are going through the gears aggressively and you mistakenly shift from 3rd to 2nd instead of 3rd to 4th then you will experience OVERREVING. Your rev limiter/fuel cutoff will still kick in but the physics involved will not stop your engine from reving past the point of no return.
Did you not get an owner's manual with your car when you purchased it? It details all of this in it.
Found my own answer in another thread.
Thank for confirming Josh.
Old Oct 11, 2004 | 07:31 AM
wanabe's Avatar
rev limiter prevents over rev normally-
except as iamjosh indicates, where you mess up and miss shift.
you can blow the engine with an over rev but thats what the rev limiter protects against in a normal rev
i see that we posted at the same time!
Mattyboyz
Sep 8, 2008 11:29 AM
fuzy24
Jun 26, 2005 06:34 AM
Banannie
Nov 5, 2003 11:37 AM
WRS2K
May 7, 2001 08:04 PM
