Painted window frame in NFR...
yeah thats def awesome... how did u take the tape out? (or wheres the forum that has the removal instructions?)... also did u have to paint it or did it come out perfectly fine?
The simplest way to do it is to leave the car in direct sunlight to warm up the tape. Open a door and grab the bottom of the tape. Just peel it off - it will take awhile and will stick quite a bit. Don't use a hairdryer to warm it up - you might heat up the surrounding glue and have a real problem.
The issue with having to paint has to do with how much sanding Honda did at the plant to knock off imperfections before they put the tape on. Mine must have had a bunch of problems with the paint because they sanded the crap out of it. I hit it gently with 3m swirl mark remover and hand polish, but I had to go into the primer to remove the sanding.
Not a big problem - couple hundred bucks at the local body shop.
I'd do it again in a heartbeat - even knowing it had to be painted. The difference is highly noticeable. Check out the european and british threads if you want to see some pictures. Their cars don't have the tape.
Originally Posted by Harpoon,Jan 15 2006, 09:09 PM
The simplest way to do it is to leave the car in direct sunlight to warm up the tape. Open a door and grab the bottom of the tape. Just peel it off - it will take awhile and will stick quite a bit. Don't use a hairdryer to warm it up - you might head up the surrounding glue and have a real problem.
Window Tape
Window Tape
Window Tape
Window Tape
maaan i finally did it and it looks awesome!
i had it painted since it was just a little bit dull... i think the car looks lower for some reason (many say it actually looks taller... but not in my opinion)...
every s2k owner should do it.... and i dont think 03> models should really need paint..
NFR_AP2
Mar 1, 2010 08:55 AM
s2grand
Feb 11, 2005 09:24 AM
