Plastic Rear Window Woes
Old Feb 1, 2005 | 10:01 AM
Kill da Wabbit's Avatar
Default Plastic Rear Window Woes
Has anyone had any problems with their rear plastic windows? Mine split right down the middle when I dropped the top last weekend.
I've tried getting Honda to fix it under warranty since I only bought the car at the beginning of November but Honda have refused. So much for paying for the peace of mind of a "Honda Approved Vehicle". When the car was in the dealers the tech. told me there was a problem with the friction plate in my clutch to which Honda have been extremely quiet when I put in my claim. Anyone else had a similar bad experience?
Old Feb 1, 2005 | 11:04 AM
s2ksimon's Avatar
pay for it and move on
and don't ever go back to that dealer
Old Feb 1, 2005 | 11:22 AM
glagola1's Avatar
It says in the manual to not lower the top in freezing temperatures. I guess you learned the hard way. If I was the dealer, I wouldn't replace it either. I liken it to an over-rev. Owner induced failure.
Also, the friction plate makes noise but it's not a defect and it will not damage the car. It's just a noise. Some dealerships have been nice enough to do the TSB and deal with honda on that. If you're out of warranty, you should just live with the noise... or pay to have a new "updated" friction disk installed.
Old Feb 2, 2005 | 08:00 AM
steven975's Avatar
i've heard even the updated disc develops the problem, too.
Old Feb 2, 2005 | 08:10 AM
S2k Dude's Avatar
The new disk remains quiet. I had a 2001 and my 2002 doesn't make near the clutch/tranny noise that the '01 did.
Old Feb 2, 2005 | 08:43 AM
Granted. I know the hood shouldn't be operated when its cold, it was 7 degrees that day (according to the airtemp sensor on my A4 ) and I'd just finished hand washing it with hot water. Makes me wonder why I paid the money for the warranty.
Old Feb 2, 2005 | 08:53 AM
PrimoGen's Avatar
I may be mistaken but the owners manual says not to drop the top if it is under like 45 degrees right? plus if you just washed it and it was 7 degrees outside then I would suspect that ice and the way below freezing temp hardened the vinyl up and it cracked under the strain of the fold.
You are most likely SOL on the window replacement without going out of pocket.
Old Feb 2, 2005 | 09:08 AM
SheDrivesIt's Avatar
7 degrees is about 45F. Well above freezing. I could see a concern for the vinyl in the top fabric if it was frozen but man. I would't think that 45 degrees would be a problem for the fabric or the window.
Damn shame is what it is. Take a look at your particular owner's manual to see what it says. Also, you can always replace the window with a glass one but I think you have to replace the entire top fabric as well.
Old Feb 2, 2005 | 09:57 AM
PrimoGen's Avatar
Not BS
https://www.s2ki.com/forums/index.php?showt...hl=window+crack
This guy had it crack at 34 degrees I guess I had the number reversed but I was simply demonstrating that it can happen at higher temps than freezing.
I also did not realize he was talking
Old Feb 2, 2005 | 10:44 AM
s2kbrian's Avatar
get a hardtop to fix the soft top plastic
Dj K-otik
Apr 19, 2004 12:41 PM
pittpanther
Oct 5, 2002 11:59 PM
GTRsi
Sep 10, 2002 03:19 PM
Michael652
Oct 27, 2001 11:08 AM
