Possible fix for for the auto-rolldown problem
Old Jul 22, 2003 | 08:17 AM
  #91
lanbrown's Avatar
I agree. This "fix" isn't a permanent fix, only the replacement part (hopefully) is.
This procedure kind of worked for me (the window with the top still didn't work) and after a few weeks, it fixed itself. I still plan on getting the updated part and having it fixed though.
*edit*
Today the window wouldn't go down with the top or with the button.
Old Jul 22, 2003 | 02:46 PM
  #92
wanabe's Avatar
just a note to report that i tried this the first day it was posted, and my fix seems to have been permanent- still works.
thanks again!
Old Aug 11, 2003 | 05:32 PM
  #93
ayrton22's Avatar
IT WORKED!! THANKS!!
Just an added note: after the window resets...it won't work for a few seconds. Just wait and try again. I also played with the passenger side window for a while..then the drivers worked.
Thanks again for sharing.
Old Aug 12, 2003 | 04:11 PM
  #94
Johnny--2K's Avatar
well..it fixed mine.........only for a while though...it started doing it again, so my delaership is replacing the window regulator for me under warranty!
Old Aug 23, 2003 | 12:32 PM
  #95
Chitah831's Avatar
This little trick worked for me, both auto window switch and when I lower the top. So great! Sorry for you folks that had it happen again.
Old Aug 23, 2003 | 12:52 PM
  #96
Johnny--2K's Avatar
had the regulator replaced, and that took care of it....no more problems.
Old Aug 28, 2003 | 01:22 PM
  #97
hornsfan's Avatar
Originally posted by F2000
AREN'T DEALERS FULL OF SHIT?
YES- I had a dealer in San Antonio tell me to make sure not to have the tires rotated corner to corner but only same side front to back! Best thing to do (he said) is bring it here for rotation.
Old Aug 28, 2003 | 03:09 PM
  #98
lanbrown's Avatar
At least they showed some intelligence in that they are directional tires, just forgot the fact that they are different widths and the rims won't go on the wrong end of the car.
Old Aug 29, 2003 | 01:02 PM
  #99
WhataRide's Avatar
Damn...I've had this auto-roll-down problem for quite some time but this fix didn't work on mine. I better take it into the dealer while the warranty is still in effect.
Old Aug 29, 2003 | 03:48 PM
  #100
Dallas's Avatar
Originally posted by lanbrown
... and the rims won't go on the wrong end of the car.
Are you sure about that? I thought that I remembered reading that you are not supposed to use the spare as a rear tire, and that if you must change a rear in an emergency, you need to put the spare on the front and use the front tire in the rear.
