post-hibernation tips?
Old Mar 20, 2003 | 06:54 AM
gohiking's Avatar
Default post-hibernation tips?
I'm planning to end my baby's winter hibernation, and wonder if there's anything special I should do (beyond oil change, check fluids, tire pressure, etc)?
Any/all tips are welcome!
Old Mar 20, 2003 | 10:09 AM
xviper's Avatar
Treat your window seals, trunk seals, hood seals with some kind of silicone grease or emulsion.
Silicone spray your 4 CV boots and 2 steering rod boots.
Give your interior a go with protectant and leather treatment.
Check your air filter (clean enough?) and filter box for evidence of mice.
Fill your gas tank up if it wasn't full at the beginning of storage.
White lithium grease all you latches (hood, doors, trunk).
Wash and polish the paint.
Check the condition of your brake and clutch fluid. They may have sucked up water over winter.
If you are really anal, pull the fuel pump fuse and crank you engine over for about 15 seconds to get the oil going before actually firing it up.
After you fire it up, check for leaks.
How's your tranny and diff fluid?
Engine coolant level?
Serpentine belt condition?
Does your battery connections need a bit of cleaning?
Old Mar 20, 2003 | 10:11 AM
DVDoughboy's Avatar
[QUOTE]Originally posted by xviper
[B]Treat your window seals, trunk seals, hood seals with some kind of silicone grease or emulsion.
Old Mar 20, 2003 | 10:22 AM
xviper's Avatar
[QUOTE]Originally posted by DVDoughboy
[B]
Man, am I glad my car doesn't have to go into hibernation.
Old Mar 20, 2003 | 10:44 AM
gohiking's Avatar
XViper -- YOU the man!
Questions:
Do you recommend a specific type of silicone grease or emulsion for the hood/trunk/window seals?
Also, afraid I'm ignorant here, is white lithium grease available at my local auto supply store?
Last question: how can I tell if my brake/clutch fluid have sucked up water over the winter?
Thanks for your help!
Old Mar 20, 2003 | 10:57 AM
xviper's Avatar
[QUOTE]Originally posted by gohiking
[B]XViper -- YOU the man!
Old Mar 20, 2003 | 10:59 AM
spidermike9's Avatar
Shin-Etsu Grease is available at www.handa-accessories.com
it is what honda recommends for your rubber seals (convert top, windows, etc)
Old Mar 20, 2003 | 11:00 AM
gohiking's Avatar
Thanks for the info, XViper!
I repeat: You the man!
Deano_d
Jan 15, 2010 03:43 PM
TRDLiquidSilver
Jun 12, 2009 07:05 AM
kidjetta
Feb 13, 2007 02:09 PM
FooF
Sep 2, 2004 11:02 AM
