preserving side reinforcement jacking points?
Old May 29, 2007 | 10:54 AM
wanabe's Avatar
the best jacking points are not on the sides anyway, imo!!
best jacking points are in the center of the car
maybe this works:
(right side of the page for floor jack)
https://www.s2ki.com/forums/index.php?act=m...d=si&img=146867
Old May 29, 2007 | 12:56 PM
RED MX5's Avatar
Originally Posted by __redruM,May 29 2007, 12:16 PM
Even if you don't, the first mechanic that puts your car on a lift will.
If the mechanic is one of ours, I want to know about it.
There's no excuse for bending the car to get it up in the air.
Old May 29, 2007 | 02:01 PM
__redruM's Avatar
I've just seen a lot of screwed up jack points. Scuffed or bent areas near the jack points on the outside edge of the car. Nothing that would hurt the frame, but certainly the type of stuff that would annoy the OP. You can usually put a lift on part of the unibody frame on the front of (the average) car, but the outside edge "jack-point" was usually the only place in the back. Next time your car goes up on a lift, see if a block of wood is used at the jack points.
I worked about 5 years as a mechanic in the early 90s, and seen some stuff that would turn you hair white.
Old May 29, 2007 | 02:31 PM
RED MX5's Avatar
[QUOTE=__redruM,May 29 2007, 05:01 PM]I've just seen a lot of screwed up jack points.
Old May 29, 2007 | 03:48 PM
propnuts's Avatar
maybe this works:
That picture looks like they're saying the rear jacking point should be the diff? I must be missing something, but since the diff has rubber mounts going to the frame that seems like a really bad place to jack from.
Old May 29, 2007 | 04:07 PM
00CivicSi's Avatar
The rear center jack point IS the diff. That picture is from the Helms service manual for the S2000.
Old May 29, 2007 | 05:07 PM
RED MX5's Avatar
... but please put a jack pad or block of wood between the diff and the floor jack.
Old May 29, 2007 | 06:58 PM
tof's Avatar
tof
As far as using a floor jack on the side jack points...DON'T. You will eventually. if not immediately damage the rib. The rib isn't meant to carry the load, the points just inside and outside of the rib are. Notice how the rib fits into the SLOT on the scissors jack.
When a mechanic lifts the car the pads extend over a much greater length of the rib than your floor jack, which is supporting the rib over a couple of quarter inch lengths. This distribution helps reduce the likelihood that the rib will deform.
If you must use a floor jack on the sides, at least use a slotted piece of wood slid over the rib.
Don't just shove the jack under the car and jack it up either. You could easily end up distorting the floor of the car. I did this on a civic years ago and it weighed a lot less than the s2k does.
Can't go wrong following the helm manual. Good post, wanabe.
StrokerSi
Apr 18, 2014 09:08 PM
Carbon Blue
Jul 20, 2010 11:50 PM
OCMusicJunkie
Dec 31, 2006 07:04 PM
revto9k
Oct 3, 2004 05:18 PM
DJHohum
Apr 10, 2001 08:35 AM
