Preventing holes in soft top - my solution
I got my 2008 two years ago and immediately insert the rubber molding on each side. I am seeing a lot of scratches and scuff marks on them. Imagine if those cuts were directly on the top. I was assuming the rough points on the convertible top frame had already been addressed from Honda in 2008 model but apparently that wasn't the case. The rubber moldings are holding up very well and everyone should do the same thing to protect their tops. Sorry don't know how to post pics here, but if you ping me, I can email you the pics of the rubber.
Do the Lizard Skins continue to be a valid option? I am willing to try anything to prevent a costly replacement; my biggest worry remains the glue seepage from for the bottom of the soft to the external side of the soft top making is quite ugly and irrevestible.
Thank you.
Thank you.
Well known problem with dozens of solutions over the years. Eliminating any burrs in the roof frame and gluing a wear pad to the inside of the roof works well. Plus never putting the roof down or up.
Wear lines will show in the roof fabric making the reinforcement location easy to spot. When I Googled lizard skin I got tape for baseball bat and tennis racquet grips. I used black Gortex parka patches on my original roof and they held up well.
My Robbins roof came with reinforcements installed onto the roof fabric where the frame can rub and my installer made sure there were no burrs in the frame.
I believe tight elastic in the roof also helps.
-- Chuck
Wear lines will show in the roof fabric making the reinforcement location easy to spot. When I Googled lizard skin I got tape for baseball bat and tennis racquet grips. I used black Gortex parka patches on my original roof and they held up well.My Robbins roof came with reinforcements installed onto the roof fabric where the frame can rub and my installer made sure there were no burrs in the frame.
-- Chuck
-- Chuck
-- Chuck
