Problems with Honda Service
Old Apr 23, 2009 | 01:12 PM
TrackStar's Avatar
Default Problems with Honda Service
Ok guys, I've been complaining about my problems with MAHWAH HONDA for a few years now. Here's the breakdown of what happened (I have receipts/dates at home, which I hope to update).
1.)
A few years ago, I brought the car in for a taillight recall. I asked for the trans/diff fluids to be changed. I got the car back, drove a few miles, and BOOM, motor blew. I checked the oil at the dealership, and alas, there was none. After a few months of arguing with them, Honda Corp decided to buy a new motor, but I had to pay around $1100 for the install. Install took a month, got the car back, and there was a check engine light. Connected MAP sensor, and pushed harnesses into their clips, and I thought I was good.
2.)
A few months later, I inspected the car and noticed my rearend was spewing fluid at the output flanges. (Comptech housing, 4.57 rearend) I bought one of a friend for around $600 or so (forgot the exact amount) and installed myself. When I looked at the invoice for the fluid change, it turns out Honda put CRV fluid in, which I blame for the leak.
3.)
A year and a few weeks after the new engine was installed, my car, all of a sudden, wouldn't rev past 3k rpm. I called Mahwah Honda, and they said bring it in, but it will not be covered under warranty. I brought it to a private shop, which charged me $900 to fix. they said the cam gears were not torqued down, and the gears "wobbled" causing timing to slip. Obviously when Honda installed, they screwed up.
4.)
My original trans started making crazy noises. I paid a few hundred bucks, plus my old set of Volks for a used AP2 trans. I dropped it off to Jeff (minitoyota) to fix, and I got a call from him today. He said a ton of bolts were missing, and grounds were not connected. Maybe he will chime in here and describe in more detail. He said the fact that the starter bolt was missing, etc., this could cause my trans to grenade itself.
This is easily around $4000 worth of problems that I don't think I should be responsible for. Not to mentions months without my car. Anyone know if I can get a lawyer to take this case? Do I even have a case?
Old Apr 23, 2009 | 01:51 PM
Izn Trbl's Avatar
Wow, I'm stumped.
All I can say is good luck to you buddy.
Old Apr 23, 2009 | 01:53 PM
leester01's Avatar
I'm sorry to hear that.
You can pay $50 and file a small claim against the dealer for $5000 and see where that goes.
Too many holes in this story for me to say if you have a case or not. From what you have posted I would say you probably don't have a case and I don't think you can honestly say that you are positive the dealer is at fault when you have had modifications done,didn't do pre-inspections,and didn't inspect your car when you left.
You stated the dealer changed your diff fluid but your motor blew from no oil? Why would they even touch your motor? Even a bad tech isn't going to do extra work.
Next your diff starts spewing oil and you are assuming it's the fluid the dealer put in that caused this but this was a used and modified diff you purchased from a friend so you don't know what the story is with that diff.
Old Apr 23, 2009 | 01:56 PM
zzziippyyy's Avatar
Im going to answer the question in your title line
Do you think I can get a lawyer.
YES they work for $ just pay there fee and you got a lawyer.
as far as the rest of your post, ill reserve comment
Old Apr 24, 2009 | 04:55 AM
TrackStar's Avatar
I got the car back from them with 0 oil in it. They drained it. There was no leak or anything. Where else could it go? I have their invoice and I looked up the number on the diff fluid, and it was for the CRV, not S2000. They probably assumed engine, trans, diff fluid change and drained the engine oil and forgot to refill.
I purchased another used diff from a friend AFTER mine started spewing fluid.
Old Apr 24, 2009 | 06:13 AM
EBungo's Avatar
ok,
under section 2. Why did you not go back to mahwah and have them rectify the problem instead of having your friend do it?
Is there a a possibility that the 2 part numbers for diff fluid supercede to each other and the part number that you have may be an older part number?
under section 3. I know where I work. all parts if not still under the vehicles factory warranty then all parts sold have a 12mo/12k warranty. So unfortunately this would apply to the engine that was replaced. Even if it was goodwilled by the manufacturer (at least where I work) Did Honda put in a remanufactured engine or did they have the dealership replace it with a junkyard one? Was it a short block (no head installed so they used your head) or a long block (where they would have no reason to remove the head)
under section 4. Did you at least contact mahwah and make them aware of the situation? or are they still in the dark about your transmission? I know if my dealership botched an install then they would want to fix the problem to help maintain good customer relations. The last thing a dealership wants is someone going onto a forum and ranting about they're dealership.
I hope this helps.
Old Apr 24, 2009 | 09:37 AM
phaphapho's Avatar
It seems like you might have statute of limitations issues since this all happened awhile ago. Go speak with a plaintiff's attorney who offers free consultation.
Old Apr 24, 2009 | 09:46 AM
TrackStar's Avatar
Originally Posted by EBungo,Apr 24 2009, 09:13 AM
ok,
I hope this helps.
2. I called the dealership and asked what the SKU# was the for the fluid on the invoice. It was the CRV fluid. I told them about the issue, and they said they must've just entered the wrong # on the invoice, and the yalways put the right fluid in. I told them I wanted my call on record. I sent a letter to Honda USA and never received a reply.
3. This is the weird part. Honda gae me an invoice with a new top and bottom end. I went to check on the install, and the head was off. it wasn't preassembled. maybe they BS'd me and gave me a used short blocK????
4. I didn't contact the dealership yet about the trans because I just found out about it.
Old Apr 24, 2009 | 10:05 AM
Stratocaster's Avatar
The head is sold complete as parts. it is a single part number that has the parts in a set of bags. You have to put the head together on the motor.
There should be a Serial number listed on the Short block section of the invoice. See if it matches the serial number of the motor. The serial number is to the right of the head, on the front of the motor. The 5 or so I have installed, all have been painted orange from the factory.
Old Apr 24, 2009 | 10:15 AM
TrackStar's Avatar
Nice thanks. I called the service department today. The 2nd in commanand admitted that they had a lot of problems with their techs, and they have new ones now. reassuring . . .
