Question pls.
Can someone give me instructions on how to take the SRS cover on the steering wheel?
It is squeaking so bad and it is bothering the heck out of me.
Thanks in advance!!!
:Kibro
:Kibro
per Helms -
Disconnect the negative side of the battery cable, and wait at least 3 minutes
Remove the access panel from the steering wheel (left side of steering column), then disconnect the driver's air 2P connector from the cable
that makes it safe, so the air bag doesn't blow in your face -- after that I not sure what you plan to do. Personally, I wouldn't touch it. It may be the air bag itself, rubbing, that your hearing.
ttb
May 1, 2004 09:55 PM
