Question pls.
Old Oct 12, 2001 | 09:57 AM
Kibro's Avatar
Default Question pls.
Can someone give me instructions on how to take the SRS cover on the steering wheel?
It is squeaking so bad and it is bothering the heck out of me.
Thanks in advance!!!
:Kibro
Old Oct 12, 2001 | 10:21 AM
johev's Avatar
I'd say ask the dealer or get a Helm manual..I think you probably have to disconned the srs system or something first...sorry my manual is at home....
Old Oct 12, 2001 | 10:54 AM
dlq04's Avatar
The quick way is to drive into a brick wall straight on. The safest way is to go to a dealer.
Old Oct 12, 2001 | 11:07 AM
Kibro's Avatar
[QUOTE]Originally posted by dlq04
[B]The quick way is to drive into a brick wall straight on.
Old Oct 12, 2001 | 11:32 AM
dlq04's Avatar
per Helms -
Disconnect the negative side of the battery cable, and wait at least 3 minutes
Remove the access panel from the steering wheel (left side of steering column), then disconnect the driver's air 2P connector from the cable
that makes it safe, so the air bag doesn't blow in your face -- after that I not sure what you plan to do. Personally, I wouldn't touch it. It may be the air bag itself, rubbing, that your hearing.
Old Oct 12, 2001 | 12:07 PM
johev's Avatar
what he said...good luck!!
Old Oct 12, 2001 | 12:56 PM
joe_s2k's Avatar
Two-words....
WD-40
schhim
Jan 10, 2015 11:12 AM
Sleepy
Nov 15, 2004 10:55 AM
ttb
May 1, 2004 09:55 PM
cyman33
May 1, 2003 06:34 PM
wanabe
Jun 8, 2001 11:14 AM
