Quick Q: Mixing Gasolines
Old Jul 20, 2006 | 04:59 PM
blue06's Avatar
Default Quick Q: Mixing Gasolines
Quick question for y'all...couldn't find this explicitly addressed searching old threads...is there any drawback to pumping a small amount of 87-octane gas into a bone-stock AP2? I inadvertently put about 4 gallons in yesterday, stopped when I realized my error, and then topped it off with 7-8 gallons of 93 octane. Mathematically, it averages to 91, but is there anything that should concern me about the presence of the low-octane stuff? The thing seems to run fine, but I didn't push it at all today. Thanks!
Old Jul 20, 2006 | 05:07 PM
smurf2k's Avatar
no problem... ecu will retard timing if octane too low.. just dont rag on the car and youll be alright. if youre so concerned, add some octane booster...but i wouldnt worry about it if you finished with 93
Old Jul 20, 2006 | 05:14 PM
xviper's Avatar
If you calculate this out, you are basically running a tank of about 91 octane. That's what's recommended for the S anyway. I don't see a need to do anything different.
Old Jul 20, 2006 | 06:16 PM
iam7head's Avatar
even if you are running anything less than 91, the ecm will retard the timing to avoid anything serious.
just don't do it too often
Old Jul 20, 2006 | 06:45 PM
smurf2k's Avatar
to ensure that the 93 is blended homogenously with the 87 go do a bunch of donuts at a local supermarket parking lot
Old Jul 20, 2006 | 07:01 PM
iamhomin's Avatar
That's overkill. The four gallons of 87 octane won't hurt your car. Gas is mixable, ECU does wonders, and you've corrected your "mistake" by pumping 93 octane.
Old Jul 20, 2006 | 07:22 PM
XclusiveAutosports's Avatar
You should be fine as others have stated, but if you are really anal than just don't pull any WOT runs until your next fill up.
Old Jul 20, 2006 | 09:39 PM
mugenrsx's Avatar
All we have around here is 91 octane. You're fine. Enjoy the car and don't make the same mistake again.
goblueS2K
Nov 23, 2012 04:29 PM
MegaTRon
Aug 11, 2012 04:39 PM
07RioS2k
Oct 1, 2008 11:20 AM
skeithr
Sep 27, 2008 06:28 PM
Dabutkus
Aug 18, 2004 03:59 AM
