really stupid question...PLEASE Help
Old Dec 29, 2000 | 04:39 PM
Marco's Avatar
Banned
In the Brake pedal and Gas pedal there are gray rubber plugs, but none in the Clutch Pedal....Are they supposed to be pulled out or left in....
Thanks
Old Dec 29, 2000 | 04:51 PM
2kturkey's Avatar
Thanks
Dunno about the US but here in OZ the plugs are in the brake and clutch pedals but NOT the accelerator. 'Tis my understanding that the rubber plugs are there to stop your foot slipping off these pedals. I think the reason they are not on the accelerator is so you can remove your foot quickly to slide across to the brake in case of emergency.
Certainly here in Oz it is illegal to remove the rubber plugs.
Old Dec 29, 2000 | 06:06 PM
Marco's Avatar
Banned
your right... Clutch and brake...not gas....
so should I leave them in or take them out?
Old Dec 29, 2000 | 09:49 PM
2kturkey's Avatar
Yep, leave em in unless you want your foot to slip off the brake under heavy brakingg ....kerrrruuunch....
Old Dec 29, 2000 | 10:43 PM
lvs2k's Avatar
The plugs are there to enhance traction in a pedal that has metal drilled out for lightness; in this case more of an effect than an actual benefit. The gas pedal has no actual holes drilled, but is made to resemble the other two pedals, I think.
Old Dec 30, 2000 | 04:31 AM
Vincelio's Avatar
Mine have plugs on every pedals : clutch, brakes AND gas
Old Dec 30, 2000 | 04:34 AM
pancho's Avatar
Mine also plugs on every pedal.
Old Dec 30, 2000 | 05:27 AM
S2000 Owner's Avatar
...and wet shoes WILL slip off the rubber nibbies!!
Old Dec 30, 2000 | 02:40 PM
2kturkey's Avatar
Yeah, but not as quickly as they will off the rubber.
mwong
Jul 25, 2010 07:37 PM
David NJ
Aug 31, 2004 08:09 PM
TheCryofMankind
Aug 16, 2003 02:43 PM
nwk00
May 30, 2003 11:11 AM
