Redline Blink?
Old Oct 8, 2007 | 07:15 PM
S2KVITO's Avatar
Default Redline Blink?
So I accidentely saw it blink when I merged into traffic today I didn't hit the limiter and I feel like a ricer now , what do ya say, it's not like a shift light? when should you shift before that split second blink occurs?
Old Oct 8, 2007 | 07:16 PM
chuhsi's Avatar
If I'm driving hard, I shift before I see the light flash 3 times.
Old Oct 8, 2007 | 08:47 PM
stevoe88's Avatar
I've never experienced the flashing light before :[ I shift as soon as I hit redline.
Old Oct 8, 2007 | 09:10 PM
hipopkboy's Avatar
when i drive hard i shift when it just about to flash or flash once, if i don't drive hard and i happen to shift to red line i usually shift a couple hundred rpm before it reaches to the light.
Old Oct 8, 2007 | 09:23 PM
FISH22's Avatar
Mine usually starts blinking right when the rev limiter is kicking in. In my old 03, it would blink about 2 times til the limiter would kick in. The Ap2's rev limiter definitley creeps up on ya a lot quicker than the Ap1, I hate it.
Old Oct 9, 2007 | 03:56 AM
S2KVITO's Avatar
yeah I def didn't hit the limiter but it just blinked one time... it threw me when I shifted lol
Old Oct 9, 2007 | 04:13 AM
chillout18's Avatar
feel kinda dumb asking but cant you blow your motor when it blinks over 3 times....I thought I read it somewhere....correct me if Im wrong so I know
thanks
Old Oct 9, 2007 | 04:26 AM
wanabmmaboy's Avatar
Where is there a shift light? Obviously not to effective because i have never seen it. Or is this a 2006+ thing? I just shift when it reaches the 8. Im starting to get the sound down where i dont have to eyeball the digi-tach at all.
and NO. It wont blow up because it blinked three times. Or because you hit the rev-limiter either.
Old Oct 9, 2007 | 05:06 AM
HighwayStar's Avatar
thanks
Limiters prevent damage to an engine by interrupting the power that is distributed to the spark plugs, this prevents the engine from operating above a pre-determined RPM level known as the red-line. The RPM level that results with the spark being arrested can be a constant level, or, with the proper ignition control modules, variable. Variable rate ignition modules can be adjusted quickly and easily to achieve the appropriate RPM limit for different situations, such as street racing, drag racing, road course racing, highway driving, and lawn turfing.
Old Oct 9, 2007 | 07:25 AM
__redruM's Avatar
thanks
No, it takes at least 4 flashes before the motor flies through the hood.
Actually though, you can bounce off the rev limiter (3-5 bounces at onces, not for 10 minutes) without too much worry. Just minimize the time at or above the redline. I hit the limiter a few times a month without issue.
Also I believe that the limiter in the S2000 is a fuel cut-off limiter, not an Ignition cut.
Finally it is possible to rev the motor beyond the limiter, and this is a very bad thing to do. the 3-2(instead of 4th) misshift can cause this...
