removal of entire antenna base
Old Nov 4, 2007 | 06:30 PM
Scheisse's Avatar
Default removal of entire antenna base
Has anyone tried removing the entire antenna base from the car? I'm trying to remove it to prep my car for paint. Thanks in advance for your response.
Old Nov 4, 2007 | 06:31 PM
BondoBuilder's Avatar
Just taped around mine!
Old Nov 4, 2007 | 06:41 PM
Scheisse's Avatar
When you painted your car, was it difficult to paint around it? I really don't like the idea of painting around that rear trim piece around the soft top along with the antenna base.
Old Nov 4, 2007 | 08:08 PM
stopmenot2002's Avatar
Here it's from top to bottom; first you need to unscrew the antenna, then the antenna nuts(has 2 or more grooves on top of the nut), just between the antenna and the base(black rubber piece seatflush on the body=called the Spacer), you remove this nut with a small plier tip, or an oring retainer plier(becarefull not to slip and scratch the nut). Once the nut is off just pull the black(SPACER) then the antenna amplifier from the inside trunk just drop, then you'r done (may have to remove the inside trunk trim to put a masking tape from inside to block paint from going inside the trunk from the antenna hole. Good luck man.
Piece of mind may used a thick rubber glove over the plier tips to prevent scratches.
An
Old Nov 6, 2007 | 07:54 AM
centralcoastbuc's Avatar
I have a special tool that I got at an auto parts store. It fits the S and also my GM type antenna base. It removes it without scratching it. I will look for it on the net.
Old Nov 6, 2007 | 09:20 AM
I have something like this.
http://buy1.snapon.com/catalog/item.asp?P6...ore&dir=catalog
Old Nov 6, 2007 | 07:52 PM
There you go, thats the right tool.
silenc3x
Jul 27, 2018 05:51 PM
elkdaddy
Feb 22, 2018 04:56 AM
elvir
Aug 15, 2011 05:00 PM
kennyr
Nov 22, 2005 02:57 AM
NFRs2000NYC
Aug 25, 2003 02:44 PM
