Removing Side Strakes
I just got my Comptech side skirts in, but I can't figure out how to get the stock side strakes off. If you have done this before any input would be most appreciated--I don't want to damage the car or the strakes in the process. How exactly is it attached to the car?
plastic clips mainly.. and some putty.. three screws on the back of it in the rear wheel well...
theres a whole drilled into the body... and a plastic piece sits in there... i haven't taken the strakes off successfully without breaking that damn clip..
Go here to see how they are put on, then you'll know how to take them off:
http://www.handa-accessories.com/S2000/s2kstrakes.pdf
Unscrew the screws in the wheel well and remove the clips, then pull the strake away from the car. The push pin will come out. Voila........now you have a hole in the side of your car.
but your replacing the skirt so no biggie.
