Removing the spring spacers
Old Jan 20, 2002 | 03:01 PM
Project Dream's Avatar
Default Removing the spring spacers
I have a little over 2k miles on my ride and just noticed that I still have a spring spacer left in my front right tire. Can I remove this by myself? Isn't it just a rubber piece I can take out?
Old Jan 20, 2002 | 03:34 PM
HondaGal's Avatar
https://www.s2ki.com/faqs/showfaq.php?threadid=17423 a pic of what the spacers look like. You can remove them yourself. You would think the dealerships would know this by now.
s2ki TSB to honda dealerships: remove the spring spacers please!!!!!!!!!
Old Jan 20, 2002 | 04:00 PM
Utah S2K's Avatar
You can remove it yourself. Jack up the car at the jack mount point on the side and corner nearest the spacer. If you look under the side of the car you will see a thin lip. At the jack points located front and rear there is a steel doubler. The points are located just inboard of the front and rear tires and can be seen as they have a "bump" to either side of them; the actual jack point is about 4-5 inches long. Once the car is raised the spring spacer can be removed. If you found one check for more..........
Utah
P.S. For safety always block your tires to prevent rolling and use a second support (i.e. 2X4's etc.). If this car comes down on you theres no going back. I tired of reading about people crushed by their cars.
tiger740
Sep 27, 2017 11:14 AM
TR-S2K
Dec 11, 2003 05:37 PM
yomike
Oct 18, 2003 10:50 PM
Prancing Horse
Aug 1, 2003 10:46 PM
bguernsey
Jan 28, 2001 06:52 PM
