Replacing the plastic front grille.
Old Feb 19, 2003 | 09:54 PM
yellafever's Avatar
Banned
Default Replacing the plastic front grille.
I'm thinking about replacing the black plastic grille in the front bumper with mesh grille. Is it easy to take the plastic grille off? Or is it permanently attached to the bumper, hence needs to be cut off? If you've had experience on this, please reply. Thanks!
Old Feb 20, 2003 | 04:09 AM
PAS2KNut's Avatar
I believe it would involve cutting, however, you can get the same look with a custom grill that covers up the hole. There are two sponsors on this site that make them.
Coastal Metals
Grille-Tech
I have the Coastal Metals grilles and like them.
Old Feb 20, 2003 | 06:47 AM
G127's Avatar
Is there a grill that will go behind the stock plastic grill? Is it possible to mount the Coastal Metals grill behind the stock one? The reason I asking it because I want to keep the stock look, but want to protect the radiator too.
PAS2KNut, your car looks good and I might do the same. Do you have anymore pictures of the grill close up and from different angles?
Old Feb 20, 2003 | 07:40 AM
dangarza's Avatar
Hi Guys, I am also interested in this coastal grille.
Was is difficult to install?
Thanks
Daniel
Old Feb 20, 2003 | 09:45 AM
mns2k's Avatar
Thanks
Daniel
When it comes to tools I am about the biggest klutz around. I installed the Coastal grille in less than 30 min. All that is required is to just attach two brackets, in existing screw holes, to the existing plastic grill. This past weekend I converted the plastic faux air intakes to the real ones that Coastal sells. Just as easy but cutting out the plastic with a Dremol tool was messy.
Old Feb 20, 2003 | 05:37 PM
xviper's Avatar
If you just want it behind the grill to protect the rad and A/C cannister, consider this:
https://www.s2ki.com/forums/showthread.php?...?threadid=70351
A few bucks and bit of your time.
Old Feb 20, 2003 | 07:34 PM
yellafever's Avatar
Banned
Thanks for the info! Your grille looks too much like stock. BUt oohh! I like the Grille-Tech and it's only $54. I may get that, but I have to think about cutting the stock plastic one. Thanks!
Oh wait! Does the Grille-Tech just go in front of the stock plastic one? Hence no cutting of the plastic is necessary.
Old Feb 20, 2003 | 08:14 PM
Stratocaster's Avatar
Yes they both go in front.
Old Feb 20, 2003 | 09:57 PM
ZAMBONO's Avatar
grille tech is much cheaper, and it is the same thing
go grille tech
JmanS2k
Dec 13, 2010 08:00 PM
dmw16
Jul 24, 2006 10:20 PM
cman321
Apr 18, 2006 01:00 PM
24s2k7
Jan 16, 2006 07:35 AM
rudeS2k
Sep 8, 2005 08:56 PM
