Replacing your convertible top with a Robbins Top
Originally Posted by bjonesz28,Feb 2 2010, 08:50 PM
Here are some pics of the bar and where the top is coming apart on both side of the rear glass.
http://i889.photobucket.com/albums/ac96/bj...op/DSC05519.jpg
http://i889.photobucket.com/albums/ac96/bj...op/DSC05516.jpg
http://i889.photobucket.com/albums/ac96/bj...op/DSC05514.jpg
http://i889.photobucket.com/albums/ac96/bj...op/DSC05512.jpg
As for the bar, it's integrity is probably ruined. Plus, it's not installed correctly. I take it they put velcro all over it to help it slide better? I don't know what all that fuzzy stuff is. There's a lot of strain on the top so once the bar is bent once, I don't see it working right ever again without some sort of auxiliary support beam.
Anyway, its suppose to go inside the two flaps that come from the area right above it. The flaps are suppose to go on each side of that bar, attach with velcro that's on them, then get inserted into the next bar. That might have a lot to do with the way its fitting together. Either way, they shouldn't have just pulled on the bar from the center. That's a recipe for disaster. If you need to pull or push the bars, it should be done at the corner bends with a guy on each side and while the top is unlatched or slightly open, never when it's fully latched and tight.
just got mine installed yesterday
costed $550 i believe plus $300 installation
def worth it
he used the old straps saying they are wider and def better...?
regardless gotta admit it really makes the car look newer
def worth it
Originally Posted by bjonesz28,Jan 28 2010, 11:54 PM
Has anyone had the rear glass part to separate from the rest of the top on the right and left side robbins upgrade? I had mine replace in June 07 and the rear bar got bent. The guy at the shop the top would not go all the way down and when they finally got it to the bar bent. We straightened it out but everytime I put the top down now it bends. sux
As a tip, if you don't feel like contacting robbins for warranty work, I would recommend using an RTV type adhesive to put it back together so it doesn't get worse. Just spread it on with a putty knife and let it dry. Works well for patches also.
I contacted Robbins today via email. They wanted me to contact the distributor that I bought it from unless I had the receipt. I did have the receipt so I sent them a copy before I left for work. I will have to wait and see what they replay until I get home.
Well I just got home and check my email. Here is some of it "Unfortunately, your top is out of warranty, and it cannot be repaired. What I can do for you is sell you a new top" I bought this top on 7/07 and I can do math this is 2/10 so thats not 3yrs. So much for 3 yrs warranty. But they do want me to call them to disuss pricing for a new top. I guess I'll call them to see if I can get it for a deal or not.
def worth it
def worth it
