Replacing your convertible top with a Robbins Top
Old Feb 7, 2010 | 08:42 AM
  #191
Cyclon36's Avatar
[QUOTE=Clovis,Feb 7 2010, 09:55 AM] Your top is not installed correctly.
Old Feb 8, 2010 | 04:32 PM
  #192
bjonesz28's Avatar
My bad I need an inside pic of the last bar. The center of the bar would be the best thanks.
Old Feb 11, 2010 | 10:30 AM
  #193
SKproductionZ's Avatar
Originally Posted by Cyclon36,Feb 7 2010, 09:42 AM
good eye. I just noticed that as well. The rear bow needs to sit along that last seam line.
lol wow! i just noticed that too now
i was wondering why it was sitting so funny, i thought maybe thas just the way it was
thank you! i contacted the installer and should have it fixed asap !
Old Mar 2, 2010 | 09:20 AM
  #194
Tyraid2K's Avatar
is there any info on where you go in these steps to:
completely remove soft top and motors for their deletion
remove the OEM seatbelts (I have aftermarket harnesses now)
re install the rear tray to have a nice shelf inside
These are my goals and I ask since I'm getting a hardtop soon.
Old Mar 2, 2010 | 10:51 AM
  #195
03 9g's Avatar
I just got a new CLOTH TOP ...its way way nicer the our OEM tops or the like , IMO if u get a new top make it CLOTH !! ...all bmw , benz etc use cloth so you have a really high look and its much more rich in color ...best of luck if u need a new top its a big job to do have done !!
Old Mar 2, 2010 | 01:04 PM
  #196
Cyclon36's Avatar
You'll need to go through the steps to the roll hoop removal to get to the seatbelts. When you take the side panels from the door jambs, you'll see a metal plate that covers the motors of the top. You can remove this plate from the body to expose the motors and their mounts. I'm not sure if the entire top with frame has to be removed to remove the motors or not. If so, you'll have to follow the directions for inner trim removal and removing the rear rain rail brackets.
Old Mar 29, 2010 | 03:20 AM
  #197
revolution's Avatar
Banned
I have an OEM AP2 roof to put onto a MY99 AP1. Obviously need the new elastic (Where can I buy this from?). Also what other bits do I need?
This roof was just taken off a wrecked AP2 and sold as is.
Also I am reading conflicting information, can I reuse the orginal AP1 frame?
Thanks.
Old Mar 29, 2010 | 03:58 AM
  #198
xoz's Avatar
xoz
modifry does the elastic also Shopman has great DIY's in his signature
https://www.s2ki.com/forums/index.php?showtopic=776615
Old May 3, 2010 | 02:11 PM
  #199
Tyreater73's Avatar
You can make the elastic straps very easily. Go to your local fabric store and get " heavy stretch" 1 1/2" elastic. Cut two 11 1-2" strips, fold the ends back 1" and stich it. Using your metal retainers as a template, heat a welding rod and burn holes through the doubled back part for the rivets. I bought 2 yards of elastic so I could practice first. Grand total, $3.18.
Don't forget to install so that the elastic doubles back over the retainer and rivets just like the factory did, otherwise the straps will be too long. Besides, it looks better and keeps an elastic layer between your new top and the metal brackets & rivets.
Old May 5, 2010 | 08:34 AM
  #200
zoomspeed05's Avatar
sweetness
