Results of Oil Filter-only change.
Old Dec 22, 2000 | 07:30 AM
pellisS2k's Avatar
I asked earlier this week if you could change the filter without first draining the oil and not expecting to get a large amount of oil all over.
Before you ask, I did this because I had drained the oil before I realized I couldnt get the filter off and needed a wrench, but I had to drive.
Anyway, Did it this morning from the top, took maybe 5 minutes, and more of that was figuring out which way to run my hands around the engine. Id estimate less than 4 ozs of oil was spilled. So yes, you can easily and relativly cleanly change the filter without chaning the oil.
Old Dec 22, 2000 | 08:32 AM
Silver S2K's Avatar
Cool. I might have been less hesitant about the 7,500 mile break in before the first oil change had I know I could have just replaced the filter at 3,500 miles w/out much effort.
Old Dec 22, 2000 | 02:59 PM
Pizzazz's Avatar
Some recommend filling the new filter with oil before installing it. Think this makes any sense? Couldn't hurt.
Old Dec 22, 2000 | 03:52 PM
Schatten's Avatar
I do this everytime I change the oil. I dont necessarily fill it, but I put a bit in there and use a little bit of oil around the seal - which gives it a better fit as a 'seal' rathern than rubber on metal.
Old Dec 22, 2000 | 03:57 PM
gregstevens's Avatar
Banned
I have never heard of filling the filter before putting it on, but I ALWAYS put a bead of oil on the gasket of the filter. This helps the seal and it also makes for easier removal...
Old Dec 22, 2000 | 03:59 PM
honda_s2k's Avatar
It is always a good idea(recommended!) to oil the seal on a new filter prior to installation. It also helps you to get an extra quarter-turn on it when tightening it up.
Old Dec 22, 2000 | 04:29 PM
wirejock's Avatar
I did just the opposite. I drained all the oil and removed the filter on the wife's car only to realise after installing the new filter. No fresh oil! Thank god I had the bike.
Coldfuse
Jan 18, 2014 03:51 PM
Av8ing1
Dec 9, 2004 04:20 PM
LostWaffle
Mar 15, 2004 06:54 PM
LIL RAJA
Mar 13, 2003 03:21 PM
pellisS2k
Dec 18, 2000 04:22 PM
