retracting piston on front brakes
You could do it with you r fingers, but just get a c-clamp and use an old brake pad to push it back in.
Much MUCH easier...!
Oh, and only the rear pistons SCREW in...the fronts need just flat pressure...
Release the top of the master-cylinder (open it), then you can use a flat headed screwdriver to compress it...very easy. On the rears, do the same thing, but you turn them clickwise to make them go in, instead of compressing them with a screwdriver...
-- Aaron
-- Aaron
All done, good as new.
