Rick's Aeroscreen vibration solution.
Old Jun 21, 2001 | 12:43 PM
dlee's Avatar
All,
I tried this and worked great for a while. Unfortunately, as I left the top down and the hot sun started beating down on it, the weather seal adhesive started to deteriorate. Once that happened, the vibration took over and started to slip the weather seal out of place. I had to constantly massage it back in place. Eventually, I decided to take the weather seal off and let it vibrate. As long as the vibration does not cause any damage to the brackets, I am happy. By the way, it only took about 2 weeks of driving and parking with top down did I run into this problem.
Any other suggestion?
Thanks
Old Jun 21, 2001 | 01:15 PM
1Y2KS2K's Avatar
Originally posted by dlee
Any other suggestion? Thanks
You're right. This fix is not permanent - especially if you keep raising or lowering the screen, or opening the secret compartment. The foam loses its form, and also quickly comes unglued if the weather's hot.
For a more permanent fix, check what Rick did here: http://www.s2000online.com/forums/showthre...ighlight=screen
Old Feb 6, 2018 | 11:49 AM
JagoBlitz's Avatar
Does anybody have some pictures of this solution?
Old Feb 6, 2018 | 05:00 PM
JS2k.com's Avatar
Sponsor
How I suggest remedying the vibration is using clear silicone. It is easily able to be removed, easy to apply, and will fix issues with vibration.
Since ricks2k has closed down, JS2k also makes the 7/8ths windscreen: https://www.s2ki.com/forums/sponsor-s2000-exterior-s2000-interior-deals-184/js2k-com-clear-tall-windscreens-moar-stickers-less-cabin-turbulence-1172399
A direct link to our windscreen: http://www.js2k.com/index.php?main_p...products_id=42
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Feb 7, 2018 | 07:58 AM
AngryTurtle's Avatar
Did you really bump a 16.5 year old thread?
Old Feb 7, 2018 | 08:51 AM
JagoBlitz's Avatar
Yeah, I also don't like the idea of gluing the rubber strips with strong adhesive to the roll hoops. I will look for a different solution, maybe silicone is the way to go. I will try it out.
Sure.
Old Feb 11, 2018 | 10:13 AM
C7_ReedZ's Avatar
Cool! Ghosts from the past! Nice to see you guys!!
Old Feb 11, 2018 | 11:03 AM
cosmomiller's Avatar
Top Answer: 1
Why wouldn't a stretchy, see through fabric work as well? I seem to see them on Porche and a few other high end convertibles.
llckll
Sep 22, 2010 11:17 AM
Mangroa
Car Talk - Non S2000
Sep 26, 2007 12:58 AM
AustinS2k2003
Jun 13, 2004 03:11 PM
Calvin
May 12, 2003 07:12 PM
Hootsama
Feb 20, 2001 11:24 PM
