rubbing on the rears!
Old Oct 10, 2007 | 09:25 PM
  #21
B.C.'s Avatar
Originally Posted by tsoshi2007,Oct 10 2007, 08:53 PM
ok i just ordered a 245 40 17 tires. so i will see if i still have to roll the fender. i will post up new pics when the 245 tires are on. thanks guys for all the information.
I don't think 245 will cut it for you, with that camber.
Try 235
Old Oct 11, 2007 | 05:10 AM
  #22
Wildncrazy's Avatar
By the time you find tires that won't rub you also won't be able to control the car. Simply get rims with the proper offset. And roll the fenders.
Just had a thought, you did modify the liner attachement point didn't you? Where the plastic liner attaches there is a tang that sticks out and plenty of tires rub there. All you have to do is get a hammer and bend it upwards some to give you more clearance. Simple fast and easy.
Old Oct 11, 2007 | 07:20 AM
  #23
N2oExpresS2k's Avatar
There is no liner on the rear.. The only reason you would have paint issues is if you pull the fenders so much that you crease the rear quarter panels. I think with 245's and a slight pull with the lip folded all the way up you should be good. The biggest problem is the lip on the inside of the quarter.
Old Oct 11, 2007 | 07:54 AM
  #24
tsoshi2007's Avatar
yes i know i should get more offset. but WORK only +44 for the most. one more question, how much to adjust the camber to neg 2 or 3?
Old Oct 11, 2007 | 08:04 AM
  #25
You're probably already between 2 and 3 with that drop you have.
Old Oct 11, 2007 | 08:29 AM
  #26
tsoshi2007's Avatar
do u know how much will it cost?
Old Oct 11, 2007 | 08:31 AM
  #27
What's it?!
Old Oct 11, 2007 | 08:46 AM
  #28
S2Krazie's Avatar
I have the same wheels on my car. IT is dropped as well. I just recently hit a bump a little to hard and broke the paint on the fender right near the tire. I am going to get the fenders rolled before i have it fixed this weekend. Rolling the fenders should do the job because it will lift the lip of the fender away from the tire.
Old Oct 11, 2007 | 08:47 AM
  #29
AP2's Avatar
AP2
fender rolling can be anywhere from $50 per fender and up....the guy in the pictures is his name is spunkysandoval on the boards and does an amazing job. he got my 9.5 +44 in the rear to clear along with my negative camber.
Old Oct 11, 2007 | 09:19 AM
  #30
B.C.'s Avatar
