S-03 or S-02's??? that's the question.
Old Jul 18, 2003 | 07:29 AM
S2K@PR's Avatar
Default S-03 or S-02's??? that's the question.
Hi
The time has come for new tires !
the car has almost 12,000 and 8 months of use.
Confused between s-03 , s-02.
Old Jul 18, 2003 | 07:33 AM
wanabe's Avatar
s02s are a bit stickier but not as good in the wet...
and not a bad choice for stock wheels.
so3s are better if you are going to diff wheels, or want a bit better weather tires and slightly longer wear.
you might want to post this in the tire forum.
Old Jul 18, 2003 | 08:24 AM
RazorV3's Avatar
if you rarely drive your car in the rain, get the s02's. you can definatley tell the performance difference b/w the s02/s03. s03 is a better "all-season" tire IMO.
Old Jul 18, 2003 | 09:12 AM
mns2k's Avatar
When I called Tire Rack to order new tires (good reason for the call) they were totally against the S03's for the S2K
Old Jul 18, 2003 | 09:21 AM
payyourtoll's Avatar
hmm, why?
Old Jul 18, 2003 | 09:34 AM
andrewewing's Avatar
Can't recommend S03s. Got 11k on OEM S02s on the rear. Only got 9k on the replacement S03s. No change in driving habits or conditions. Decided to swith to Yoko ES100. Very happy, although too new to judge wear rate.
Old Jul 18, 2003 | 09:40 AM
koala's Avatar
S-02's are a much better performance tire. Not to mention the tread design looks better, hahah.
Old Jul 18, 2003 | 09:47 AM
RoBD305's Avatar
For this change defiantely stick with S-02. Your fronts are still good and are S-02's. Mixing the front S-02 with rear S-03 can be bad especially in emergency situations. If you want to change to S-03's change all 4 or wait till your front S-02's wear out. IMO stick with S-02, can't go wrong. The S-03 are a downgrade in grip on dry surfaces but an improvement in the wet. Good luck. Rob
Old Jul 18, 2003 | 03:16 PM
ricosuave's Avatar
i've had both rear s02's and s03's (with front s02's). the treadlife on my s03's was shorter. and i agree with the consensus that s02's are better dry weather tires and they're lighter too. as for the all weather aspect, i can't really say s03's made a difference (maybe it would if i went with s03's all around). stick with the s02's.
my 2 pesos.
Old Jul 18, 2003 | 05:55 PM
VeilsideAP1's Avatar
switch to Yokos....
moonwalker
Jul 14, 2008 02:40 PM
GotRPMs
Apr 15, 2004 06:30 AM
SstoneS2k01
Mar 3, 2004 07:03 PM
kumar75150
Jan 26, 2002 09:05 AM
rahul
Jan 19, 2001 06:17 AM
