S2000 Gas Milage
Originally Posted by ThuG LyFe,Sep 19 2008, 07:46 PM
sorry but it feels like i see a new mpg post every week...but it's good to see s2000's get good mpg. another pro to add to my countless reasons why s2k will be my next car.
[QUOTE]
Originally Posted by S2Kage,Sep 20 2008, 08:20 AM
Whats VtecH?
http://www.vtechkids.com/
Take your pick.
Originally Posted by ACoF,Sep 20 2008, 08:30 AM
Originally Posted by sandiegan,Sep 21 2008, 09:48 AM
I commute a lot usually get near 28mpg or 26 mpg with a couple of VTEC sprints
Originally Posted by S2Kage,Sep 21 2008, 06:32 AM
hmm i dunno, I always was under the impression it was 13.2 gallons.
Nice milage on CTSC... I take it your not full throttle too often?
The Centrifugal CTSC is a great way to get allot of power without allot of gas usage. 260 per tank is with lots of full throttle pulls, as many as I have room for, its too much fun. Thats why i got aprox 40 less miles per tank when I was N/A. 300 N/A was lots of hard running as well. The thing with a SC is it uses no more fuel when driving normal then an N/A car and obviously thats the majority of the driving on the street. A N/A car driving with the AC on would see less mileage on a tank then a SC car without, and certainly the N/A car would feel much more sluggish.
If you spin the CTSC pulley on the car when there is no belt attached you will notice there is no resistance, its almost like spinning a wheel on a skate board, therefor there is no power loss or drag on the engine to turn it when just cruising around, there is however constant forced air flow to the engine even though not under enough for boost register. I experienced under normal driving more engine response and less heat soak overall. In my experience I believe that driving with an CTSC if never brought into boost could likely see marginal better fuel mileage. This however is only a factor with conservative boost levels wile maintaining the use of factory fuel ejectors, I am pushing that threshold at 8 psi. Running 650cc at 10psi for example isn't going to work for fuel mileage, but 7psi or under with stock ejectors is likely, but with no boost usage as stated.
