S2k Passenger window is stuck
The basics; '02 S2000 with a hardtop.
I tried opening the passenger side window this morning, nothing. Doesnt make any noise of any kind, it just won't go down. I've read that others have had similar problems & it ended up being the power-window-lock switch. Rest assured, ive tried this thats not it..
I have also checked the fuses underneath the steering wheel & those haven't blown...
I'm not sure if this is a mechanical problem that requires a new regulator or a simple electrical quick-fix. Any input would be greatly appreciated!
positive. i switched it back & forth several times & attempted to lower the window with no luck. neither switch works (driver side or passenger side)
keep in mind, my driver-side window works 100%...
you can always pull the panel off the door... but then you still might find out whats wrong.
hmm i would just rip the panel off and see if anything is jaming it or a wire got pulled out or somthing,
if you take it to a dealership i think they will do the same thing unless they pull codes so its up to you.
If you have a friend with an S try swapping the soft top control module. It's behind the dash on the passenger side. Dave (601WHPS2K) had the same problem with his. Driver window worked fine, passenger didn't. We swapped the control module and it started working just fine.
it sounds like he knows what hes talkng about,me on the other hand not so much lolol sorryyyy
jammer2209
Mar 15, 2011 12:49 AM
