S2k Passenger window is stuck
Old Dec 28, 2010 | 03:47 PM
spanisholive1's Avatar
Default S2k Passenger window is stuck
The basics; '02 S2000 with a hardtop.
I tried opening the passenger side window this morning, nothing. Doesnt make any noise of any kind, it just won't go down. I've read that others have had similar problems & it ended up being the power-window-lock switch. Rest assured, ive tried this thats not it..
I have also checked the fuses underneath the steering wheel & those haven't blown...
I'm not sure if this is a mechanical problem that requires a new regulator or a simple electrical quick-fix. Any input would be greatly appreciated!
Old Dec 28, 2010 | 05:36 PM
aklucsarits's Avatar
Are you SURE that the window lock is not on?
Andrew
Old Dec 28, 2010 | 05:47 PM
positive. i switched it back & forth several times & attempted to lower the window with no luck. neither switch works (driver side or passenger side)
keep in mind, my driver-side window works 100%...
Old Dec 29, 2010 | 07:42 AM
lazymashi's Avatar
could be broken window regulator...
happened to a friend of mine... her's is MY04...
Old Dec 29, 2010 | 10:37 PM
s2cho's Avatar
you can always pull the panel off the door... but then you still might find out whats wrong.
hmm i would just rip the panel off and see if anything is jaming it or a wire got pulled out or somthing,
if you take it to a dealership i think they will do the same thing unless they pull codes so its up to you.
Old Dec 29, 2010 | 10:48 PM
adidas_man's Avatar
If you have a friend with an S try swapping the soft top control module. It's behind the dash on the passenger side. Dave (601WHPS2K) had the same problem with his. Driver window worked fine, passenger didn't. We swapped the control module and it started working just fine.
Old Dec 30, 2010 | 12:06 AM
s2cho's Avatar
do what he says it sounds like he knows what hes talkng about,
me on the other hand not so much lolol sorryyyy
Old Dec 30, 2010 | 12:36 AM
wittman's Avatar
my drivers side door does this sometimes when its cold out. I just punch the door and then it works fine
elkdaddy
Feb 22, 2018 06:10 PM
plizzat
Aug 10, 2015 03:49 PM
jammer2209
Mar 15, 2011 12:49 AM
blippy
Mar 21, 2010 11:44 AM
ewcollins
Mar 22, 2002 07:48 AM
