SC + 4.xx gears
Old Feb 19, 2006 | 07:30 PM
WindchaserS2K's Avatar
I'm running Vortech SC 9lbs/4.57
Old Feb 19, 2006 | 08:19 PM
Johnny Sack's Avatar
et's? kills? let here em!
Old Feb 19, 2006 | 08:53 PM
CosmosMpower's Avatar
Originally Posted by sahtt,Feb 19 2006, 06:36 PM
If stock cars can hit high 13's...
with aggressive gears hit low/mid 13's...
it should surely hit mid 12's with SC and a good driver.
I'd say low 12's are a given with slicks/drag radials and a good pilot.
Given the RWD, near midship, 2800 lbs, close ratio transmission platform of the s2k, adding 50-100hp or significantly modifing the gear ratios will have fairly substantial reduction in 1/4 times.
No one with just gears and boltons runs LOW 13's on street tires, maybe 13.3-13.5 I can believe. The average S2000 owner can't even hit 14.0 stock, it takes a hell of a launch to get high 13's stock.
Old Feb 20, 2006 | 05:21 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
13.7 stock;13.2 with gears;13 flat with gears +I/H/E/;12.2-12.5 with SAC added.!!!
Old Feb 20, 2006 | 06:11 AM
Wisconsin S2k's Avatar
an S2000 with just the SC at stock boost, can hit high 12's.
a 4.57 geared S2000 can hit 13.3 with no other mods. (this is about .5 seconds off the ET of a stock S2k)
so, an S2000 with SC and gears should be able to hit low/mid 12's with a great driver.
Old Feb 20, 2006 | 07:14 AM
vbb's Avatar
vbb
Ahh the biggest variable of all!
Do I think low 12s is possible with a supercharger, slicks, and 4.56s or 4.77s? Yes, it might be possible. But people have a hard enough time as it is piloting a stock S2K to 13.8.
Add the stick of slicks: Launch gets more tricky
Add the power of a supercharger: Launch gets even trickier
Add the acceleration of gears: Shifting comes quicker and more frequent, which leaves more room for error in a 1/4 mile pass.
So even your good drivers that are able to hit 13.8s stock will have even a harder time hitting low 12s with the mods listed above. Your average drivers? Forget about it. Cracking into the 12s consistently will be tough.
You're probably the #1 drag racer on this site and even you aren't turning the low 13 second passes with the gear upgrade if I remember correctly.
I'm not saying low 12s aren't possible, I just don't want anyone to get their hopes up.
Old Feb 20, 2006 | 07:32 AM
[QUOTE=vbeachboy,Feb 20 2006, 10:14 AM] Ahh the biggest variable of all!
Old Feb 20, 2006 | 07:39 AM
vbb's Avatar
vbb
Originally Posted by Wisconsin S2k,Feb 20 2006, 12:32 PM
so we should blame the car for the driver? what sense does that make? they wanted to know if it was possible. not how probable it would be. so the answer is, yes, with a great driver, it's most certainly possible.
give me a 4.57 geared S2000 with an SC, and I'm willing to bet I could get it there once I had enough practice to adjust.
and, FYI, I've only been to the track twice with my new gears. I've made maybe a total of 6 or 7 runs in them. And, there ARE people who HAVE run 13.3 with just the gears. I witnessed one owner do it one two seperate occasions.
Not sure I follow you on the "blame the car for the driver" comment. I was just saying that an S2K equipped with all of those things might be capable of a low 12 second pass at the 1/4th mile, but it's unlikely that someone who isn't either a professional driver, or drag races every weekend will see those times.
However the car will be blisteringly quick (top speed will be limited though).
And I don't doubt that a S2K with just gears CAN hit 13.3s, but I was just using you as an example of someone who drag races more than most, but still doesn't have one of those timeslips under your belt to show how much practice and skill it takes to run the times that some people are throwing around as if they are given. I didn't realize that you'd only had a few passes with the gears though.
Old Feb 20, 2006 | 07:43 AM
hyperion_'s Avatar
Originally Posted by kayvan_pour,Feb 19 2006, 02:25 PM
Yea, with an sc and gears... And just a nice exhaust I could see low to mid 12's...
and perhaps a broken differential? :S, already broken my diff. on my totally stock s2k. So no SC for me
Old Feb 20, 2006 | 07:45 AM
billmesh's Avatar
I don't know for fact, but it seems entirely possible and probable that you would be in the mid-high 12's with the SC and gears. Throw in an upgraded pulley, some engine management and tuning and I'll bet that's low 12's for sure.
