Shaking Shift knob
Old Apr 28, 2010 | 06:53 AM
Frez2k's Avatar
yea its normal, but you said that it is uncomfortable to put your hand on, just a reminder, you shouldn't rest your hand on the shifter unless you are about to shift, you dont want to rest it because it will push it where is shouldnt be, even the smallest amount could be bad, let the shifter rest naturally unless you are about to shift. I heard this from a good mechanic
Old Apr 28, 2010 | 07:19 AM
operator207's Avatar
I have heard this put into more of a racing/driving term. Keep both hands on the wheel, put your hand on the shifter only to shift, then move it back to the wheel. Seems like a safe thing to do regardless of if your racing or just driving on the street.
But I know what your saying, I have seen people use the shifter as an "oh shit" handle in turns. If your going to do that, use the hand brake. However, if your going to make a turn fast/hard enough to *need* an "oh shit" handle, you really should have both hands on the wheel.
Old Apr 28, 2010 | 09:03 AM
dammitjim's Avatar
Make sure the plastic spacer thing on the end of the shifter isn't cracked or damaged. Might as well regrease the shift lever while you're at it. There is a diy.
Old Apr 28, 2010 | 10:23 AM
Reckon's Avatar
Mine shakes but nothing drastic.
Old Apr 28, 2010 | 11:18 AM
NOLA_AP2's Avatar
Originally Posted by Presto123,Apr 28 2010, 09:40 AM
Normal.
People say an engine torque dampener stops the vibration.
Not true. I have a spoon engine torque damper and it still shakes. It's never bothered me.
Old Apr 28, 2010 | 12:35 PM
Blendo's Avatar
The shifter in my S2000 has maybe a 1/4" of play left/right when running.
Shifter in my old Ram SRT-10 moved around at least a full inch.
It did have huge shift lever to magnify the vibrations...
In either case, it is normal for a direct-mounted shifter to vibrate.
Old Apr 29, 2010 | 10:44 PM
Kodokan_4's Avatar
Mine used to shake a lot.
With the J's engine torque dampener, it hardly moves.
Old Apr 29, 2010 | 11:04 PM
CKit's Avatar
Mine shook. The driveshaft bolts were loose.
Old Apr 30, 2010 | 02:37 AM
kaissi's Avatar
[media]http://www.youtube.com/watch?v=SNLleen-iwA [/media]
65 mph..
6th gear...
I'll try to take another video soon at a higher speed.
Old May 3, 2010 | 05:52 PM
KDashy's Avatar
Completely normal, I can barely see any movement in the video.
My 240sx had bad motor mounts and vibrated about 10x worse than that.
