Shaking Shift knob
Old May 4, 2010 | 07:34 AM
  #21
NoContest's Avatar
Originally Posted by kaissi,Apr 30 2010, 02:37 AM
65 mph..
6th gear...
I'll try to take another video soon at a higher speed.
Looks like mine but are you holding the video cam with one hand & driving with the other - and how are you lining up the shot? Talk about both hands on the wheel
Old May 4, 2010 | 08:12 AM
  #22
rob-2's Avatar
really... guys the shifter is linked directly to the tranny which will vibrate.
This is not a problem.... move on
Old May 4, 2010 | 10:37 AM
  #23
thomsbrain's Avatar
Completely normal. The entire drivetrain (including the engine itself) will move around a lot, and the shifter is directly attached to it.
As others have said, don't touch the shifter unless you are shifting. This is good practice regardless of the car.
Old May 4, 2010 | 11:57 AM
  #24
aCab's Avatar
Noticed it, but never even questioned it.
Old Jun 11, 2010 | 07:21 PM
  #25
1slowS2K's Avatar
ok, turns out my engine mounts were causing the vibrations, so I replaced them with the full Megan engine and tranny mounts. Car runs and shifts 10X better, no vibrations!
Old Jun 12, 2010 | 04:57 AM
  #26
nartnailuj's Avatar
where did you buy them at?
Old Jun 12, 2010 | 06:41 AM
  #27
s2kroly's Avatar
Mine does it also, i kinda like it makes me feel like im connected to the engine.
Old Jun 12, 2010 | 09:09 PM
  #28
hrpfg2's Avatar
mine shakes also, a buddy said it was my mounts but i refuse to agree.
Old Apr 18, 2017 | 05:25 AM
  #29
r6shifter's Avatar
Talking
sorry to take this out of the grave... the only person that pinpointed something related with this problem was actually
Originally Posted by CKit
Mine shook. The driveshaft bolts were loose.
Buying an S2000 out of a dealership it would not shake to the point that its painfull or that it becomes a strange fact .. thats just logic playing here guys.
some troubleshooting points on this:
- engine mount is busted,
- dif mount is busted
- your propshaft needs re grease and/or re calibration
- your propshaft bolts were loose,
- you have a damaged bearing on your gearbox.. (hopefully not)
yes the s2000 propshaft can be re-greased.
good luck!
Old Apr 18, 2017 | 06:20 AM
  #30
starchland's Avatar
good luck!
can you please elaborate on the propshaft regrease and calibration
