shaky rearview mirror, how to fix?
Old Sep 3, 2006 | 09:49 AM
madsedan's Avatar
Default shaky rearview mirror, how to fix?
I did a search but didn't come up with much.
I've tried tightening the center crew but it doesn't really help, vibrates so bad while driving its almost useless.
Do I need to remove the screw and put a small washer so the screw can tighten up on it?
Old Sep 3, 2006 | 10:42 AM
xviper's Avatar
Ordinarily, the mirror shouldn't be shaking that bad. Mine is fine. You might want to find out why your car is vibrating so badly.
Old Sep 3, 2006 | 01:28 PM
madsedan's Avatar
Fixed it. I found another thread you had done on removing the mirror that had some pics.
I pushed it back up into the sliding bracket and tightened the screw, all is well now, thanks.
Old Sep 3, 2006 | 02:09 PM
xviper's Avatar
Hmmm. I'm glad I was able to help you though I didn't really help you.
Old May 31, 2023 | 10:26 AM
VTEC4-2's Avatar
Mine shakes between the mirror and the base, the interface which pivots (breakaway feature). I've had many honda/acura products, and it seems to be a common trait.
Inside there is friction material and an indent. As the friction material wears or perishes, the mirror is left without on-center material and small rotations occur over bumps. Not a serviceable item, the only reason I know is I broke a mirror years ago and tore it apart to see inside.
Back to the S2000, I was able to dampen the vibration using a rubber band to fill the gap. I selected a yellow band for my yellow car. Solved the issue for both mirrors. I suppose those rubber bands will also perish, I'll just keep adding a new one.
WarTowels
Nov 4, 2015 08:28 AM
S2005x
Mar 1, 2008 07:26 AM
s2kdarren
Sep 9, 2004 07:53 AM
Ghost
May 8, 2004 03:19 AM
Silver1
Apr 15, 2004 06:13 AM
