SHIFTING
you need to have your transmission gears rebuilt.
popping the gears out is a sure sign of rebuild. grinding as well with clutch all the way in.
I've had this, I have a new transmission via honda warranty (thanks rob).
it's expensive. about $5000. but most honda dealers will not rebuild your transmission for you. rather, you probably have to buy a new one.
good luck.
good luck.
Originally Posted by CaptainMike,Jan 29 2008, 12:34 PM
I would say 20-25 in 4th is lugging. (Bogging)
On a level road the car will accelerate smoothly from 20-35 MPH, in fourth gear, under light throttle, without lugging. Acceleration has to be VERY LEISURELY because anything more than a light application of the throttle will cause lugging.
Lugging comes from excessive throttle relative to the load. Bogging takes place when the load exceeds the available torque. Slightly different things.
If the car is regularly poping out of gears then it is time to rebuild/replace or at least take it in for warrenty.
It may not be true for a car that popped out twice in 10,000 miles, but it's not normal either.
Here is the TSB for popping out of 2nd. I have not seen 1 for popping out of 4th.
With the AP2 transmissions, the consensus has been that if you have a low milage car that pops out very occasionally when cold the problem will generally resolve itself by 10K miles of so.
If you have a car which is constantly grinding and popping out of gear hot and cold you obviously have a screwed up transmission and need it repaired.
But the very occasional grind, or cold pop out (especially if you're not sure you put it all the way in gear) does not automatically require a new transmission as Plokivos unequivicably stared
05-009
Transmission Pops Out of 2nd Gear
SYMPTOM
The transmission intermittently pops out of second
gear on high RPM deceleration.
CORRECTIVE ACTION
Replace the countershaft 1st gear and the 2nd
gear set.
PARTS INFORMATION
First Gear:
P/N 23421-PCY-010, H/C 7596869
Second Gear Set:
P/N 23432-PCY-316, H/C 7596893
REQUIRED MATERIALS
Honda Manual Transmission Fluid
(1.7 quarts required per vehicle):
P/N 08798-9016, H/C 4928271
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 213205
Flat Rate Time: 8.2
Failed Part: P/N 23432-PCY-316
H/C 7596893
Defect Code: 03214
Symptom Code: 03701
05-009
SYMPTOM
CORRECTIVE ACTION
gear set.
PARTS INFORMATION
First Gear:
Second Gear Set:
REQUIRED MATERIALS
Flat Rate Time: 8.2
H/C 7596893
Defect Code: 03214
Symptom Code: 03701
Originally Posted by RED MX5,Jan 29 2008, 02:54 PM
Maybe. Maybe not. It all depends on the throttle setting. Consider the extremes. If you're coasting, the engine can't lug unless the engine speed drops below idle speed (and then the engine is pulling, or trying to pull, so you are no longer coasting, and the engine will bog rather than lug). Even if you are in fifth gear at 1500 RPM, if you're not on the gas at all, the engine can't lug. No throttle application, no lugging.
good luck.
good luck.
