skip shifting the S2000?
Old Dec 1, 2008 | 10:10 PM
detonator2x's Avatar
I try to stay in each gear until 4k at most then shift. Unless the noise gets annoying, then i'll work the gears up to 6
Old Dec 1, 2008 | 11:25 PM
jonner's Avatar
I only skip shit to quieten the engine down after ive been flaking it along just in case theres any coppers around...
Old Dec 2, 2008 | 05:18 AM
Triple-H's Avatar
I skip all sorts of shifts. The key is if you can do perfect or nearly perfect rev matches. If you can't, skipping gears is not a wise idea.
On the street I'll often go 1 to 2 to 4. I can't run the revs to 9-grand in 3rd without being way over the speed limit, but I still want to enjoy VTEC, so I run it hard in 1 and 2, and then mellow out into 4th. And if I should be running along in 5 or 6 and want a sudden burst, I'll go right down to 2 or 3rd.
On the track I downshift from 5 to 3 many times per lap, taking the time to go from 5 to 4 to 3 is just a waste of time.
And of course, I would never skip gears to save fuel economy, that's just wrong...
Old Dec 2, 2008 | 05:57 AM
Vilstar's Avatar
I shift anywhere between 2-4k rpms. But if you're looking for better gas mileage, it would be in that range and not accelerating hard. If you're accelerating hard through the gears then it defeats the purpose.
Old Dec 2, 2008 | 06:00 AM
Rodney's Avatar
i will echo doug's comments. i skip shift frequently in all my other cars, but not in the S. not because i can't, i just like running through the gears...
Old Dec 2, 2008 | 06:17 AM
thebig33tuna's Avatar
https://www.s2ki.com/forums/index.php?showt...=0&#entry204419
be careful with your synchros...
Old Dec 2, 2008 | 07:31 AM
Rodney's Avatar
i have been driving like this for 20 years, and NEVER had transmission issues.
Old Dec 2, 2008 | 07:59 AM
i wasn't directing that at you in particular, just posting it up for the millionth time for others to read. if you don't want to read the post i linked that's fine but i would highly recommend it.
Old Dec 2, 2008 | 08:02 AM
hirev's Avatar
i have always done this with all my cars. i suppose it saves some gas. my favorite is 1-3 going down a hill and starting in second on a hill going down it. just listen to the car , if it luggs or the gearbox gives you some resistance then don't do it. i also do 6-3 sometimes on off ramps. i always rev match my downshifts.
Old Dec 2, 2008 | 08:10 AM
ECale3's Avatar
I never skip gears. I cruise at 75mph which has the engine spinning at 4000rpm.
