So How Much Did Honda Leave On The Table?
"Sorta. Government is the reason we have OBD2 in our cars, so a case could be made it's the government's fault we can't remove our cats, not the ECU. The actual processor in Honda's latest batch of ECU's have been the same since 1992. Oh, and OBD2 isn't engine management, it's emissions systems monitoring. The management system is all Honda."
I was refering to the technical aspect of removing the cat, not the legal ($10,000 fine if you're really unlucky) aspect.
Emissions control and engine management are one and the same. Yes OBD2 is emission monitoring at it's most basic level but it also includes emission strategy, new mil requirements, catalyst protection and generic data stream capability.
The generic data idea was really only for the emissions inspection programs. It is pretty much useless conpared to the OEM pids and bi-directional controls, I use it only as a last resort.
Originally posted by Luis:
The F20C has a slightly thinner head gasket than our F20C1 and F20C2 which raises compression to 11.7 producing another 10HP in the process.
By the way, Spoon has an even thinner head gasket that raises compression to 12.2. Don't know what the HP claimed gain is.
whats the "piston to valve" and "piston to head clearance" like? Do you think we could change to the thin headgasket without interferance problems. Just detonation problems.
Is there enough room for a big cam without modifying the pistons first?
Originally posted by VaporTrail:
During WOT, the ECU goes to a map similar to that of the cold start map. It pretty much ignores the oxygen sensor during this sequence. All parameters are geared towards performance at this point. This is why some have added FPR, to compensate or to take away fuel during WOT runs in which the ECU does not compensate.
Some GM OBD2 vehicals maintain fuel control even at wot. They use o2 data at wot. On the dyno, you can see with a labscope that the o2 sensor waveform is moving but is biased rich.
[QUOTE]Originally posted by Roceye:
[B] Vapor,
[B] Vapor,
QUIKAG
Aug 4, 2016 10:42 AM
