Source of rodent smell
Old Aug 4, 2021 | 06:48 AM
REVS29K's Avatar
Originally Posted by cosmomiller
You may have to check the undersides of the seats to see if Mr Rodent decided to nest in there. After that, put a blanket on the sill, and on your back, with flashlight or headlight, look all under the dash, both side, to see if one of them nested/died up there. They love eating wire insulation.
If you find nothing, it is possible they are in the console. After that, pop the door panels to see if they are nesting inside the doors.
I had an Integra that had them nest in the vent/heater duct. Cleaned it out twice but couldn’t get rid of the smell and traded the car.
Old Aug 4, 2021 | 08:02 AM
rmayhew's Avatar
Default rodents
Originally Posted by moran
I'm experiencing a strong almost overpowering rodent smell in my 2003 S2000 that is likely a mouse nest or mouse urine or worse. I'm unable to find the source and wondered if others having experienced similar invasions have determined the likely location of the deposit from which the smell is emanating? Both actual experience and likely suspicions will be helpful. Thank you.
I use match light charcoal briquets under the hood to chase away these critters before they eat wiring.... I glue fiberglass window screen into pouches with gorilla glue and tuck them into the fenderwell areas....
Old Aug 4, 2021 | 11:33 AM
Saki GT's Avatar
This is quite frequent in the hot summer months. The hamster in our tiny four-banger gets a bit musty when you're working it out with those high redlines!
Open the hood and find the running wheel, and give the little guy a good hosing off, to reduce the odor. If you want to really clean it out, a gentle bath and towel, then let air dry, and then place back in. Feel free to offer a carrot for a nice hp boost.
Old Aug 8, 2021 | 05:30 AM
Filthy Beast's Avatar
Get a few cats.... i had one nest under the cowl during the winter. The stink was over powering
Its almost impossible to get the odor out, i tried everything from Lysol to odaban. 2 yrs later it
still lingers. Im going to have the interior Ozoned when i get time.
Old Aug 8, 2021 | 09:50 AM
cosmomiller's Avatar
Top Answer: 1
I wonder if Servepro would do something like that. Just like it never happened.
Old Aug 8, 2021 | 01:07 PM
I haven't thought about Servepro but they probably would.
Most high end car detailers have a ozone machine to
get the stink out for used cars for dealers.
Old Aug 25, 2021 | 07:24 PM
datadr's Avatar
If you really want to find it, pull the seats and start pulling the panels behind the seats and remove the entire trunk liner and panels - it's not hard to do and doesn't take much time. There's lots of places for critters to hide/nest in those areas. Also, did you CHANGE the cabin filter? Or just check it? I would change it out to be sure it's not an odor in the filter itself, even if it looked clean.
Old Aug 26, 2021 | 05:50 AM
Nedpoins's Avatar
I had that problem at the beginning of the summer. Looked everywhere without tearing things apart and found nothing. About 3 weeks ago, the odor went away. Now it’s fine.
Old Aug 26, 2021 | 09:22 AM
Top Answer: 1
When you notice turkey vultures circling your car, you know it is bad.
Matt_in_VA
Jun 28, 2014 12:04 PM
