spare removed - compressor and fix a flat shoved in a bag in the old space...
Old Jun 29, 2003 | 03:16 PM
thereisnospoon's Avatar
Default spare removed - compressor and fix a flat shoved in a bag in the old space...
hope its the right decision... oh yeah - AAA in the wallet helps too.
Old Jun 29, 2003 | 03:23 PM
Saud2k's Avatar
did you do that for wieght savings?
Old Jun 29, 2003 | 04:45 PM
Luft46's Avatar
I put my amp in there
Old Jun 30, 2003 | 04:31 AM
weight savings and I am planning on putting a changer in the tool foam area to maximize space. I also had jumper cables and some other small things (tire gauge) that I wanted out of the way - so into the bag and into the spare tire area.
Old Jun 30, 2003 | 05:25 AM
ruexp67's Avatar
Does it rattle around, or did you wrap it all together?
Is there any concesous on what happens to the wheels when using fix-a-flat?
Old Jun 30, 2003 | 05:57 AM
Russ's Avatar
Please be aware one can of fix-a-flat is usually for 16-inch tires or smaller. If you have larger tires, you might want to store another can up in there.
Old Jun 30, 2003 | 06:16 AM
actually - I think the size rating is just for the inflation amount. IE - the can can only reinfalte a tire so much without needing a compressor to properly inflate the tire. I have used a regular 16" rated can of fix-a-flat on an 18" Porsche wheel/tire and it worked ifne using their compressor to finish it off. If you think about it the BMW mobility system is just that - its doesnt actually have more sealant.
Nothing rattles - I put everything in a bag (oil, rag, jumper cables, compressor and fix-a-flat) and then stuffed it in. to make sure it doesnt slide out i just screwed the orignal spare tire bolt back in as a barrier. Works great.
Re: fix-a-flat sealant - it will ruin a tire once its inside. They get out of balance as it dries - but I am not one to patch or repair a high-performance tire to begin with. I'd rather replace it compeletly for peace of mind. The wheels just need to be cleaned up before remounting the new tire.
solitarycheese
Oct 2, 2014 08:19 AM
TRD_Celica
Jan 8, 2011 11:46 AM
GodoftheBOLP
Sep 15, 2004 10:22 AM
kjgood
Nov 5, 2003 09:39 PM
Partshelper
May 17, 2003 07:17 PM
