Speaker install question
Old Jun 21, 2001 | 07:47 PM
Weasel's Avatar
Default Speaker install question
I want to install two more speakers in my stook. I am assuming that since the head unit has a fade control in addition to a balance control, it must have outputs for four speakers. I am not a guru at audio installs. Can someone out there with knowledge of the head unit tell me if indeed there are four outputs and where on the unit they are located on the unit. Any advice on accessing the unit without using a sawsall on the dash would also be welcome .
Old Jun 21, 2001 | 08:34 PM
Tanqueray's Avatar
Here is MacGyver's site with lots of info:
http://users.rcn.com/dhintz
Old Jun 21, 2001 | 09:07 PM
Skarv's Avatar
While McGyver might show the wiring.. The subtlety in this question is where the wiring ends.
The head-unit does indeed have the outputs you need.
The problem is that the wiring harness that connects to the head unit has no wires to these pins. That means that for you to tap into these 'speaker outs', you will have to install pins, with wires soldered on, into the honda harness plug.
Exactly which pins are which channel is easy to figure out with a Voltmeter.
Good luck.
Dan
Old Jun 21, 2001 | 09:09 PM
vmb's Avatar
vmb
Rumor has it that there are no rear outputs. The fader is a big fat lie. Maybe someone in the electronics forum can confirm??
Old Jun 21, 2001 | 09:10 PM
vmb's Avatar
vmb
hmmmm. Skarv's post wasn't there when I typed mine!
Old Jun 22, 2001 | 03:41 AM
lucid's Avatar
coolness, I started a trend... Its a bugger to get the stock radio to work for the rear speakers. I highly recommend getting a new head unit, with the right setup you wont need an amp. Check the electronics forum for more in-depth topics on this! Let me know if i can help in any way.
Old Jun 23, 2001 | 07:34 AM
MacGyver's Avatar
[QUOTE]Originally posted by vmb
[B]Rumor has it that there are no rear outputs.
Old Jun 23, 2001 | 09:41 AM
Y2K++S2K's Avatar
Also keep in mind that the MUTE button will not mute the rear speakers. Only the front! This is reason enough not to use them in my opinon. Just buy a 4 channel amp.
tdots2k
Apr 30, 2013 09:20 PM
2SoonS2K
Oct 13, 2012 05:41 AM
seminolejoeusa
Jul 15, 2012 08:22 AM
owenxguo
Oct 12, 2004 09:24 PM
