starter button grind
Old May 13, 2003 | 05:53 PM
gerryk's Avatar
Default starter button grind
If you push the start button while the the car is running should you get a grinding sound? sometimes i do and sometimes i dont.
Old May 13, 2003 | 05:55 PM
Tiger8119's Avatar
i have done it 2 times on accident that is and on both times i heard the grinding sound
Old May 13, 2003 | 05:59 PM
xviper's Avatar
If you didn't have the clutch to the floor, then you won't because the starter will not have engaged. It will pretty much always grind because the speed of the flywheel is so much faster than the speed at which the starter bendix is turning. The teeth simply won't mesh.
jpotts's Avatar
yes - that's like turning the key when you have a car running...go try it on a cheap, button free car, it will make the same sound...
bottom line, if it grinds, I'd think don't do it again...
Old May 14, 2003 | 04:39 AM
Legendary 88's Avatar
OOooooo....I hate the noise
bgoetz
Apr 29, 2015 06:14 AM
mndthegap1
Dec 6, 2010 11:44 AM
hondaBeater
Mar 20, 2008 08:21 AM
pledge
Apr 29, 2007 11:41 PM
mc2
Apr 12, 2006 07:34 PM
