Starting Issues
Old Oct 4, 2025 | 04:26 PM
Car Analogy's Avatar
Originally Posted by Ian67
nope Chuck everything on dash lights up but nothing when you press the stsrt button,as i posted earlier i think it's heat related in some way as if I leave the car for a bit of time it does fire up first push.
You originally said 'no ignition'. Maybe that is meaningful slang across the pond, but here it implies, but isn't clear about it, that the starter is spinning the motor, but with ignition it never fires up.
When asking for troubleshooting advice, you must be explicitly clear about exactly what does, and doesn't happen. Ambiguity is the enemy here.
Nothing when you press the staet button still leaves room for confusion. Especially since no ignition (ignition means spark at sprk plugs, igniting engine and starting it) implied more than nothing. A potential contradiction.
So once again, what exactly happens when you press start?
Does the starter spin the engine?
Do you hear any sounds, even a click? From where?
Do the dash lights dim or any other observations?
Old Oct 4, 2025 | 08:56 PM
Ian67's Avatar
Originally Posted by Chuck S
Next time this happens pull the START button from the dash and jumper the contacts and see what happens. If the car starts (unlikely) the switch is bad if not it's down toward the starter solenoid (more likely).
-- Chuck
cheers Chuck having considered I think the solenoid option is the most likely.are you able to advise
​a.how do I do option 1
b how do I do option 2
your replies are much appreciated!
Old Oct 4, 2025 | 11:17 PM
Ian67's Avatar
When I start it in the morning there's no problem,
Once I arrive at my destination if I return to the car relatively quickly; local shop trip for instance ; the dash all lights up no noise that i can hear when i press start.
if however it's left for a period of time it starts no problem- hence my thinking it's something to do with an engine heat issue,?
Does that make sense ?
Old Oct 5, 2025 | 01:32 AM
noodels's Avatar
Check
Low tension lead on starter motor.
Old Oct 5, 2025 | 03:25 AM
Ian67's Avatar
Originally Posted by noodels
Check
Unfortunately noodles I ain't a mechanic so I wouldn't know what to look for but thanks i'll try to find someone local.
Old Oct 5, 2025 | 06:51 AM
You still weren't explicit, but apparently you mean:
When issue occurs, I press Start, and literally nothing at all happens. Nothing. No sounds, no clicks, no dimming of dash livhts. Definitely rrrrr, rrrrr sound indicating starter motor is turning engine round and round.
The dash lights are already on, bc they went on when key turned to start position.
Is that correct?
And never, not even once, not even a little bit, did any of that stuff ever happen when this issue occurred. Yes?
But later, once things cool down, it starts fine. Yes?
The reason this matters is even the slightest clue could lead to a completely different diagnosis. Rule things out, etc.
This is how diagnostics is done. On everything. Cars. Computers. Medical. Everything.
Careful observations turned into explicit, unambiguous information is vital. Or else you get the wrong diagnosis.
If all above is true, something is preventing the starter from getting any power at all, but only when hot.
The starter uses more battery juice than any other system in the car. That is why the cables to it so fat.
But they can't route those fat cables to Start button. So instead, they use this sorta remote control switch, called a relay. An electromagnet. Skinny wire to Start button, powers up magnet. Magnet pulls big, fat switch like in Frankenstein's lab, which is right at starter. Mad power to starter. Vroom.
But wait, there's more! Its not an ordinary relay, its combined w other stuff to become, A SOLENOID. Tada!
This electromagnet also pulls a level that pushes the small gear from starter motor out to engage flywheel teeth. The moment that gear is fully engaged, that is when the Frankenstein switch makes contact.
Gear engaged, switch turns on, starter spins, gear spins, flywheel spins, engine spins. Engine starts (if everything else works).
If the lights dimmed, or you heard a click, or some other symptoms, that would tell us some power is getting to starter,or at least solenoid, but not enough to either fully engage electromagnet, or possibly jist nit enough fpr starter to spin all that engine stuff (the exact symptoms would guide us which of these).
Since literally nothing at all happens, we know no power is getting to that electromagnet. That is the issue.
Ok, but why?
Could be a lot of things. Could be the Start button. Could be a frayed wire, that when stuff gets hot, doesn't make contact. It could even be the electromagnet has some semi shorted wires in that big loop of wire that goes around the metal core that makes the magnet magnety, but they only short put and touch when things are hot (metal expands, etc). So it doesn't even try to pull the lever.
A mechanic can put a meter or even just a test light on that skinny wire on starter (that powers solenoid), have someone press Start, see if that makes juice appear at skinny wire.
Yes, that points to solenoid. No, that points to something in wiring path. A wire, the start button, etc.
See, you're not a mechanic, but this stuff isn't that hard to learn.
Old Oct 5, 2025 | 10:13 AM
Ian67's Avatar
Is that correct?
Ok, but why?
wow that's a brilliant reply CA thanks v much.
​​​​I'll contact a local diagnostics guy this week and see if he can idolate the issue
thanks everyone f
nichigo
Jul 14, 2017 06:32 AM
SuperHamz
Sep 16, 2016 01:19 AM
S2000ap12k
Jan 9, 2014 05:53 PM
Sushumna
Oct 4, 2010 01:54 PM
Jwslick
Mar 16, 2010 04:41 PM
