Steering problems
Old Aug 2, 2009 | 06:44 PM
Thanhstar's Avatar
Default Steering problems
Hi..
I have a problem with my steering after a friend of mine drove my car into a curb with the front drive side... i was not there, but he came back with marks on my lip and a bent one of kind rpf1.. along with a steering wheel that is about 45 dregree off to the left to go strait.. and my steering feels a bit heavy when i make right turns.. the wheel is replaced, i jacked up my car and don't see signs of anything bent.. the toe on each side matches up.. some help please
Old Aug 2, 2009 | 07:01 PM
Mark355's Avatar
Did he say how fast he was going? Double check your alignment and then go from there...
Old Aug 2, 2009 | 07:14 PM
Swift GT's Avatar
Is he still your friend?
Old Aug 2, 2009 | 07:15 PM
AlX Boi's Avatar
Did he bend over as he returned the keys?
Old Aug 2, 2009 | 07:23 PM
Apollo's Avatar
Take it to the dealer and get it fully assessed. Your friend better be opening up his wallet with a smile.
A friend of mine curbed his car and needed his control arm, tie rod, damper, and rim replaced.
Old Aug 2, 2009 | 10:36 PM
macr88's Avatar
It's extemely hard to tell if the control arm is bent, and if you had to replace a wheel I can almost guarantee that it's bent.
GL with it.
Old Aug 2, 2009 | 10:49 PM
smurf2k's Avatar
my steering wheel was off by that much
also HAD to replace the wheel
but an alignment put everything *almost* to specs. control arm and steering knuckle was only *slightly* bent such that it maxed out at slight slight negative camber. everything else (toe, caster) was within spec.
so get that shit aligned
Old Aug 3, 2009 | 05:39 AM
takeshi's Avatar
Originally Posted by Thanhstar,Aug 2 2009, 06:44 PM
some help please
Don't let that friend drive your car anymore.
Old Aug 3, 2009 | 05:55 AM
MurderS2K's Avatar
kill him. but all the above information was what i would suggest. could be anything man, you need it checked out.
at worst - steering column (rack and pinion) OH WHAT A NIGHTMARE!
Old Aug 3, 2009 | 09:06 AM
digitalcassette's Avatar
the economy is tough all over, i bet you could pay a couple low rent thugs to break his knees lord knows your so called friend deserves it
BTW what was your friend doing in your ride without you?
s2k_suprchrgd
Jul 2, 2010 12:19 PM
Master Apex
Sep 12, 2008 12:18 PM
Urge
Feb 6, 2007 03:44 AM
Sbeall
May 13, 2004 03:52 AM
scottrnelson
May 28, 2001 08:42 AM
