stupid question: second gear
Originally Posted by donnys2k,Jul 6 2006, 10:29 PM
ok ill try to explain this better during wot 2nd gear only seems to be useful for two or three seconds as opposed to all other gears i go through which are useful for much longer
for some reason 2nd gets to redline much quicker than others
hard to explain but hope that helps what i am experiencing some
Its the same reasoning that 4th would be slower compared to thirds and so on.
So basically 1st gear you start out under VTEC cams unless you launch car. And 3rd,4th so on are dealing with drag and wind resistance.
Originally Posted by donnys2k,Jul 6 2006, 09:31 PM
i can only hit 48 in 2nd before it redlines
You cannot be sure that you are going 48 mph in 2nd at redline because the speedometer has a lag and unless you hold redline for at least 2 to 3 seconds, you really can't say what the real speedo reading would be. Even if you could, without a YB, it would not be correct anyway.
Yellow Box looks like this. It's only a couple of inches long.
When you do a WOT from a stop, you will indeed notice that you will have to shift again within let's say a second after having hit redline in 1st! It goes pretty fast through the gears when on the power cams
My motor is just fine. I just meant that once you shifted into second gear, you will have to change again to 3rd within a second or two. I was not suggesting hitting the rev limiter in 1st for a second or two.
AP1 6000 - 9000 Vtec
Cold engine, the rev limiter comes in about 7500 RPM. Avoid this! Make sure you have half a tank of heat - 3 bars showing on the guage.
With a warm engine, I shift at 40, 62, and 90. 40 to 62 only takes a couple of seconds.
Interesting. My Escort ZX2 shifted at about the same speeds with a 6500 redline and 7000 rev limiter.
