Suspension question
Old Jul 24, 2004 | 04:34 PM
AndyS2's Avatar
Default Suspension question
I have Neuspeed springs, and when I do "spirited" driving thru the canyons, i start rubbing my tires on turns becuz of slight body roll. There isnt really much space between the fenders and the tires, with 18VolkGT-N, SO3 and Neuspeed combo.
I dont like rubbing while i am taking corners and I am sure the rubbing would be much more if I would take the care to the track because fo hihger cornerspeeds (when I dont have the fear of headon collison or flying off the canyon I drive faster ). The car is fine while i am doing regular driving.
I belive I need harder springs, I am not ready to go with coilovers or adjustable suspension so I need springs, just harder.
Any siggestions?
Old Jul 24, 2004 | 05:23 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Rolling the fenders my be an option, lots of guys have done it with great results...
Old Jul 24, 2004 | 05:27 PM
AndyS2's Avatar
is there a DIY on it?
Old Jul 24, 2004 | 06:22 PM
dispader's Avatar
It's probably best to have someone do it for you if you have never done it. Because if you mess up, than you got a busted fender. There is a tool that bolts onto your hub that makes it real easy. If you could get one of them somehow, it would make life easier.
Old Jul 24, 2004 | 07:07 PM
E36Ap1's Avatar
Make sure they use a heat gun. So that the paint doesn't chip when they roll it I heard it good to do it on a hot day not a cold day. But I would have someone else do it so you can blame them if something happen.
Old Jul 25, 2004 | 02:50 PM
AndyS2's Avatar
are kgmm springs hrader then neuspeed?
Old Jul 28, 2004 | 05:58 PM
Billman250's Avatar
Top Answer: 1
If your ever in New York, the Metro crew can roll the fenders first class for 20 bucks
Old Jul 28, 2004 | 06:04 PM
dispader's Avatar
the kg/mm race springs are stiffer but they drop 1.5". It would be more cost effective to roll your fenders first to see if that fixes it. You could try a skinnier tire as well.
drifts2
Sep 24, 2014 08:28 PM
AP1Driver
May 10, 2014 08:21 PM
mitzy
Jun 1, 2010 03:56 PM
S2KBreaker
Apr 27, 2007 05:07 PM
03S2kStud
Mar 26, 2006 02:51 PM
