Swapping carpet
Old May 28, 2006 | 12:00 PM
nj2tn's Avatar
Default Swapping carpet
I have done a few searches and found no good DIY for swapping the carpet out.
Can anyone help.
I'm swapping my tan interior out for black tomorrow and don't wana get stuck on one little thing for 2 hours.
Old May 28, 2006 | 01:26 PM
Blue_S2's Avatar
Its pretty easy overall. There are little clips all around the edges. I forget how many but some of them can be a beeeech to get out. The ones by the pedals are harder.
Old May 28, 2006 | 02:36 PM
ruexp67's Avatar
Take out the seats, door sills and trim plastic. Remove the center console too. There is also a bracket under the gas pedal to remove. Remove the net on the passenger side.
Remove the seat belt anchor bolts. There are a LOT of washers in there, and it is a LONG bolt, so be VERY careful removing it so you can put it back together again.
There are many plastic clips around the carpet from behind the seats (under the "vented panels") to all the way down the center console on both sides. These all pop out. A trim removal tool will help a lot.
Inside the footwells there are two screw out clips (one on each side.)
You do have to cut the carpet over the center console near the back of the center console right at the bottom of the glove box. You also need to cut the carpet inside the footwell area behind the radio.
Overall it took 3 of us about 6-7 hours to remove the carpet, seats and door panels from two cars and reinstall them in the opposite cars.
Old May 28, 2006 | 02:55 PM
Blue_S2's Avatar
6-7 hours It took me and another guy 4 hours to do our cars and swap.
Old May 28, 2006 | 02:59 PM
nj2tn's Avatar
Sweet. thanks for the info!!!
Old May 28, 2006 | 03:58 PM
ruexp67's Avatar
Well, that does include a lunch break, but yes. We took our time, we wanted to be careful and get it done right.
BTW -- To the original poster. THIS is the time to install sound deadener if you have ANY thoughts about doing it. Dynamat, eDead, or whatever. It will be EASY to do the floor with the carpet out.
Old May 28, 2006 | 04:37 PM
darkfx's Avatar
I can strip out my interior in under 1.5 hours
Old May 28, 2006 | 05:39 PM
IheartS2ks's Avatar
Hell, I could probably do it in 30min with a box cutter and no remorse.
Old May 28, 2006 | 06:40 PM
Nate03's Avatar
on a full swap - door panels, carpets, console & seats - took 3 people - working carefully (including - gratefully - the very meticulous Billman250) 4 hours to swap between two cars...
other than around the gas pedal the carpets are pretty straight forward... the console requires a cut intot he grey material under the radio and under the cover ... that will also be pretty obvious once you get to it... the only way to avoid the cut under the radio is to pull the dask & I don't think that's necessary for an interior swap...
good luck.
Old May 28, 2006 | 06:47 PM
nj2tn's Avatar
Hopefully tomorrow afternoon i'll post some pix.
Thanks again for the input.
RUEHL925
Feb 22, 2014 04:52 PM
aLcm
Jul 28, 2013 08:39 PM
bavarian06
Feb 4, 2008 07:25 PM
vietthuqstyle
Mar 7, 2007 11:43 AM
BioBanker
May 30, 2004 04:03 PM
