Switching to synthetic oil
Old Aug 31, 2005 | 07:27 PM
sunrise089's Avatar
Default Switching to synthetic oil
Surprisingly, I have had no problem finding plenty of info on switching FROM synthetic, but I cannot find a thread about switching to synthetic from conventional. If someone could point out any relevant thread to me, I would appreciate it. Specifically I am switching to Mobile 1 Synthetic, and need to know if I need to do anything different than I would with a normal oil and filter change. Thanks
Old Aug 31, 2005 | 07:44 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Nothing special.
Just drain the oil,change filter,add syn.oil,and enjoy!!!
Old Aug 31, 2005 | 08:07 PM
xviper's Avatar
If you have leaks, fix the leaks first. Going synthetic with a leaky engine, will only make it leak worse. If it's tight, switch away.
Old Aug 31, 2005 | 08:23 PM
sunrise089's Avatar
Well my '02 just hit 17k miles, so I'm thinking I should be pretty leak-free. Sound reasonable?
Old Sep 1, 2005 | 02:46 AM
decker's Avatar
i switched to synth after 50k, before my engine ate a quart of oil ever 3-4k and now...nada.
Old Sep 1, 2005 | 04:33 PM
wanabe's Avatar
my hint- install a fumoto valve...
makes changing any oil easier and no more crush washers needed!
other than that, synthetic is just a type of oil- except you dont have to change it as often!!
shingojr
Sep 20, 2007 08:21 PM
Lunacy
Jan 28, 2003 12:10 PM
GundamZ
Aug 7, 2002 12:17 AM
enzyme
Nov 18, 2001 07:07 AM
NDAZONE
Mar 12, 2001 09:00 AM
