Thunk In First Gear from Standing Start
Old Jan 23, 2008 | 03:14 AM
JonasM's Avatar
Have your dealer check the rear spindle nuts. Supposedly, the torque spec on it was increased. I was having some thunks back there, and while I was in for something else, I mentioned it. The tech found the service bulletin, and ended up replacing the spindle nuts and increasing the torque on them (they did this for free as a good will gesture).
It says it's for '00 - '02, so this may not apply to you.
https://www.s2ki.com/forums/index.php?showt...0&#entry4063088
https://www.s2ki.com/forums/index.php?showt...0&#entry4178748
JonasM
Old Jan 23, 2008 | 03:36 AM
MIAMI S-2000's Avatar
Originally Posted by meccjoo,Jan 22 2008, 03:38 PM
ive actually found that if you slowly push the shifter into gear then the thump will either be minimized or you wont even feel it. i guess depending on how fast you engage the gear the more youll feel the thumk
Old Jan 23, 2008 | 05:42 AM
smurf2k's Avatar
Originally Posted by hoof,Jun 2 2003, 06:24 PM
I often get a thunk when I have the car in neutral while stopped with the clutch out, then depress the clutch and engage the gear.
The reason for this thunk has to do with how the gearbox is set up. The clutch has two parts to it, one is attached to the engine crankshaft, another goes into the gearbox. This second shaft can spin freely (when in neutral) or is "engaged" via gears to the rear wheels. However, when the clutch is engaged, this second shaft *must* spin at engine rpm or slip.
Thus, when you have the clutch out in neutral, this shaft/clutch half is spinning at idle rpm, because the engine is spinning it. When you push the clutch in, the clutch disengages, and the shaft is essentially free-wheeling. When you engage the gear, if the shaft is still spinning, the synchromeshes in the gearbox have to accelerate the shaft to wheel speed, which is zero when stopped. *That* is the thunk I was talking about in the first part of the post.
The "solution"? Wait a few seconds after pushing the clutch in before engaging the gear.
The way to check if this is the thunk is to drive your car. At a red light (or anytime after stopping), put the car in neutral and let the clutch out. Then push the clutch in, followed (within a second or two) by putting it in 1st. You should hear a "thunk". If this is the same sound thunk you're hearing, then there is no problem. If this is not, there may be something else going on (which might require a mechanic to look at).
Someone mentioned that this shaft piece weighs 18lbs. I'm not sure if that's the right number, but it is a fairly hefty piece of metal, if I recall it right.
very nice write up
my older car clunked pretty often going into 1st. unless i stop and go back to first immediately , it almost never ever happens
Old Jan 23, 2008 | 06:55 AM
SoMe0nE2tAlK2's Avatar
Mine had the thunk when I first drove it at the dealer. Salesman said it was normal. But I assumed that the salesman didn't know shit so I asked another s2k forum and they said it was normal
Old Jan 23, 2008 | 12:22 PM
shy_guyAP1's Avatar
Whenever I notice something and wonder about it there is a new thread on it here.
I guess it's normal then for the thunk?
Old Jan 23, 2008 | 12:54 PM
KnowledgeIsPower's Avatar
my car is a thumper
Old Jan 23, 2008 | 01:23 PM
alejo's Avatar
wholy old thread batman!
Old Jan 23, 2008 | 01:26 PM
txs2knoah's Avatar
so more like 3 years and 6 days now
i have a thunk to
Old Jan 23, 2008 | 03:58 PM
AcePlease's Avatar
Normal. C'mon, it's a Honda. Don't worry too much about it.
When it stops running, then worry. LOL
Rio Sunset
Mar 6, 2015 03:21 PM
DillonS2000
Jun 17, 2014 07:58 AM
s2kpr01
Aug 12, 2006 12:54 PM
Brutewes
Jul 3, 2003 09:33 PM
MJMSC
Mar 3, 2001 01:04 PM
